Home > Wheels & Tyres > Tyres rubbing!
spam242
Tyres rubbing!
A friend of mine has just fitted some 35 12.50 15’s to his 1996 90 and is now suffering from some arch rubbing even after cutting down a bit. Has anyone fitted these tyres before and if so how did you over come the rubbing?
Post #774621 23rd May 2019 10:45pm
Procta
Might be best to look at raising the suspension, also I have seen some defenders with cut down front wings too when they run these sort of tyres too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #774639 24th May 2019 6:05am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
It already has a lift on it.You can see the cranked arms in the pic.
Cut the arches. Thumbs Up
Post #774642 24th May 2019 7:13am
spam242
Yeah it’s running a 2 inch lift, already trimmed the arches. Is the next step cutting the body work?
Post #774648 24th May 2019 8:03am
sharkey964
Where is it rubbing.Back/front,on full lock???
Mine does'nt rub since cutting the arches & adjusting the steering stops.
I have 2" lift,& full Gwyn Llewis suspension set up,+5" OME shocks.
Marc
Post #774668 24th May 2019 9:19am
Ndamico
Canada 2004 Defender 110 Td5 CSW Alpine White
Which OME springs did you go with? 04 110 TD5
Post #789988 2nd Sep 2019 12:38am
