Home > Maintenance & Modifications > Chequer plate load liners
sfrankland
England 2009 Defender 110 Puma 2.4 USW Indus Silver
Hi all
I'm after some advise. I use my defender daily and as a work vehicle (I'm an electrician) so I wanted to try and keep the back in good condition. I have some rubber matting down but I don't like it so was thinking of using chequer plate to line the back.
I wasn't sure if I would need an air gap between the chequer plate and the actual bed (I'm worried about condensation and then water unable to get out)
Has anyone else fitted anything like this? I guess it would be the same if fitting a drawer system.
thanks in advance
stu
Post #771568 4th May 2019 10:10pm
williamthedog
I put chequer plate in the back of mine from new (8 years ago) Recently removed the old piece from the floor, it was getting a bit tired. Underneath the tub floor was still like new. Thumbs Up
Post #771586 5th May 2019 6:59am
sfrankland
Excellent! I was hoping someone would tell me that! Did you use anything to actually fix the plate down? I was wondering about a bit of silicon to help it stay in place as didn’t really want to drill holes. The weight of my tool should keep it in place anyway
Post #771589 5th May 2019 7:59am
Co1
You would be fine with strips of sticky back foam, or silicon. Like you say, the weight of tools will stop it shifting.
Post #771592 5th May 2019 8:10am
williamthedog
I used silicone around the edges, also on mine (a 90) there are 2 m6 bolts going through the floor for the wing supports underneath. So I bolted them down through the plate as well.
Post #771597 5th May 2019 9:09am
sfrankland
Excellent. Thanks guys. I’ll put the order in.
Post #771621 5th May 2019 2:50pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Having had old farm vehicles with bare metal in the back I'd keep the rubber mat. Everything slides around on metal flooring and anything loose rattles like a b*&*^&%.
The absolute best stuff I have ever come across is what I use in the back of my pickup, it is a really heavyweight mat that is designed as non-slip floor for carrying animals on board ships. Weighs a ton and is totally non slip even when wet and almost indestructable. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #771631 5th May 2019 4:35pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I did this to mine after replacing an already fitted ply floor that had been screwed in. The ally has been riveted and bolted where appropriate. Plate is 3mm all round.
Also had a storage box made. The rubber mat is covering the plate which is also fitted to the floor. I needed the mat to stop everything sliding around.
 Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #771662 5th May 2019 8:19pm
williamthedog
I put this horse matting in the back when the dogs are in the back. It stops them getting that sliding feeling. Thumbs Up
Post #771663 5th May 2019 8:29pm
sfrankland
I think I’ve come across that stuff in a stables before. Strong stuff!
Post #771670 5th May 2019 9:22pm
sfrankland
Wow that looks great! Pretty much what I’m after but I’m going to ply and carpet the walls so I can use them for materials storage.
Post #771671 5th May 2019 9:24pm
sfrankland
Looks great! Luckily my tools boxes fit side by side exactly and 6 deep so sliding shouldn’t be an issue for me.
Post #771673 5th May 2019 9:26pm
I have it in mine, very pleased with it for the purpose it serves.
I have a Genuine HT mat in the centre as well for the dogs, but the stable matting would do just as good a job really.
Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #771675 5th May 2019 9:46pm
TobyMellin
United Kingdom 2000 Defender 90 Td5 HT Santorini Black
I'm a mobile HGV mechanic. I'm always chucking heavy stuff in the back and the floor was starting to look a bit rough, so i bought this one off a mate of mine.....
Post #772254 9th May 2019 11:28am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Just removed the rubber mat in mine after the heavy rain over the last couple of days and guess what...it was sodden underneath. So, decided to leave the rubber mat out for a few days to help dry it out. Reason for post is the potential for water underneath any flooring you put it if you defender is not water tight Shocked
Post #772834 12th May 2019 8:20pm
