Home > Technical > Td5 bbus fire |
Blimey, I've never heard of that one before How did you become aware that it was on fire? Darren
21st Apr 2019 5:00pm |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 31 |
I had just stopped to talk to someone and noticed a burning smell which i never thought much of until i moved off and the thick smoke appeared from the bonnet edge, luckily i had a fire extinguisher at hand i gave it a blast and managed to unplug it. Nothing else is damaged luckily apart from my boxers 😂
21st Apr 2019 5:19pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
That is proof (if ever anyone needed it) that you should always carry a fire extinguisher in your vehicle 2002 90 Td5 Station Wagon
21st Apr 2019 6:00pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 584 |
From the picture, battery is on the opposite side of the connector, so they are probably not the origin od fire. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
22nd Apr 2019 6:18am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1760 |
Blimey that's not great! Does answer an idle musing of mine about whether it would be possible to replace the cells in the bbus though!
22nd Apr 2019 9:51am |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
Lucky you caught it when you did, did the battery look scorched? Perhaps if the battery had gone bad, the incoming charge caused it to overheat. 2014 Keswick Utility 2.2
22nd Apr 2019 12:21pm |
