Home > Technical > Noise when turning truck off...
Stacey007
I forget what it's called,
When I switch the truck off it makes a sound, sort of shut off valve? Anyway it's got louder. Quite a bit louder and more 'dry' sounding.
What part is this? Does it need replacing or greece / oil?
Easy enough to do?
Thanks
Post #766712 3rd Apr 2019 7:56pm
hank
Is it like a chatter chatter chatter sound? If so it’s the EGR self cleaning procedure > 110 XS Double Cab
> Instagram @simonlanemind
Post #766713 3rd Apr 2019 8:01pm
hank
Post #766715 3rd Apr 2019 8:03pm
LR90XS2011
Google EGR valve DEFENDER 90 TDCI XS,
Post #766720 3rd Apr 2019 8:38pm
Stacey007
That's it but the clatter is louder now😲
Any idea how much the part is ? Puma 2.4
Thanks all
Post #766723 3rd Apr 2019 8:43pm
Procta
can you not just remove it and bin it off? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #766761 4th Apr 2019 6:08am
LR90XS2011
there are loads of threads on here regards the EGR try the search function most suggest an increase in noise indicates a clean or replacement is required DEFENDER 90 TDCI XS,
Post #766762 4th Apr 2019 6:10am
Ihod
United Kingdom 1998 Defender 90 300 Tdi ST Rioja Red
Thanks all
The part number is LR006650 - £150ish for genuine.
You might go through the threads and see if you want to remove it/isolate it. But if you do want to replace it I happen to have a spare (never fitted as I had the existing one isolated as part of a remap) - new in box (I think with the gaskets) - you're welcome to it for £60 plus the postage? Ian
MY1998 300Tdi 90 Hard Top (Now Soft Top)
MY2015 110 XS SW - Sold
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hard Top - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #766783 4th Apr 2019 9:48am
Thon
My new EGR was actually much noisier than the old one. I replaced it because it was repeatedly throwing up one or more warning codes. I seem to remember reading that if blanking-off the EGR you need to write it out of the ECU but stand to be corrected on that one.
Post #766807 4th Apr 2019 11:13am
You only have two options;
1) Replace for new. Standard map tune.
But it will need replacing again at a later date.
2) Fit a blank inlet side and get a tune with EGR shut permanently.
This way is permanent and if combined with fuel additive I would say cleaner and more efficient in the long run full stop.
There is certainly an MPG increase with both and definitely not a placebo. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #766835 4th Apr 2019 1:32pm
