Home > My Defender > 1993 Defender 110 CSW Rebuild
Page 3 of 3 <123
L110CDL
Spot on, there is always something about an engine in place on the chassis, very nice Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #649468 10th Sep 2017 9:57pm
Retroanaconda
This thread needs updating again.
With the engine in the chassis I got the gearbox crossmember painted up and bolted in:
I then set about cleaning up the engine as it was pretty grimy. Cue some disassembly of ancillaries, many hours of brushing and scrubbing, followed by some paint and reassembly:
Post #760868 26th Feb 2019 8:36pm
Retroanaconda
Once all back together it was time got another quick test run:
Post #760870 26th Feb 2019 8:38pm
Retroanaconda
Next challenge was the hole in the bellhousing left where the clearance for the starter motor was added. After consulting with others and with some good help and advic I devised a cover plate out of some bits of aluminium and had them welded on by a local engineering company.
Post #760873 26th Feb 2019 8:42pm
Retroanaconda
Onto clutch. The flywheel was drilled for the standard Tdi 9.5” clutch or a custom 250mm jobbie as used by M&D in the original conversion. The latter is no longer available so the option from M&D now is an updated Tdi clutch. Personally I would prefer to have as big a friction area as possible so I had the flywheel drilled for the Td5 clutch cover which uses a 10.5” clutch - the same as the V8.
Clutchfix made me up a set of Td5 cover and a V8 (sprung) friction plate which seems to do the job. Got it stuck on the back of the engine and then built up the clutch actuation bits and got the gearbox bolted on:
Post #760874 26th Feb 2019 8:50pm
Co1
Great Work πŸ‘
Post #760875 26th Feb 2019 8:51pm
Retroanaconda
Last bit of progress which brings us more or less up to date.
Got the transfer box cleaned up and bolted on, this is a 1.2 box from a Discovery and I will have to see how it drives. Might end up going back to a 1.4 if I don’t like it but I may as well try it seen as I have the box already.
Also bolted on a front prop so I can start thinking about the exhaust.
The middle and rear box will be standard Td5/Tdci 110 units, however the front one requires a custom arrangement due to the non-standard engine. Given that the exhaust outlet is on the offside of the engine I need a pipe that crosses over like a Tdci one does, so my plan is to get a de-cat downpipe for a later vehicle and modify this to fit.
Post #760876 26th Feb 2019 8:57pm
Alitaff
Fantastic πŸ‘
Post #760880 26th Feb 2019 9:23pm
L110CDL
Great work done there and all those hours paid off with cleaning the engine up and that is sounds sweet Very Happy
Great work on the aluminium cover and great update Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #761083 27th Feb 2019 9:30pm
Oldyellar
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Nice work mate
Post #762918 11th Mar 2019 6:38pm
Fatbaron
Great build thread Retro! Thumbs Up
Post #763406 14th Mar 2019 1:50pm
Page 3 of 3 <123
