Home > Technical > Td5 springs on a Tdi |
They're all completely interchangeable. I fitted a set of take-off 2016 springs and shock to my old 1992 90 and it was a straight swap. Darren
26th Feb 2019 3:23pm |
Alf_B Member Since: 17 Dec 2016 Location: Chelmsford Posts: 7 |
Oh perfect, thanks for the speedy reply!
26th Feb 2019 3:34pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Are the 110 rear springs not different from the 90 rear springs? Diameter? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
27th Feb 2019 6:29am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5449 |
Yes, but not year dependant.
110 Tdci will fit 110tdi 90tdi will fit 90tdci |
27th Feb 2019 9:18am |
Fortunately mine's a 90. One last thing, has anyone had any experience with spring isolators? Do they result in a bit of a lift? Or make any difference at all regarding cabin volume?
27th Feb 2019 12:43pm |
Isolators are generally a good thing, although they're designed to reduce harshness rather than noise. They do provide a small lift, in the region of 10mm, but you'd be hard pressed to tell without a tape measure.
This is my 90 following installation of new suspension including D1 isolators on the rear and D2 ones on the front: Click image to enlarge You can see the full details of what I installed HERE. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
27th Feb 2019 1:20pm |
