Home > Maintenance & Modifications > What’s this now? |
andrewlandy Member Since: 07 Feb 2016 Location: Graz Posts: 82 |
..after cleaning, and about 4 hours and 60Kms..
Click image to enlarge |
4th Feb 2019 9:56pm |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
I have heard there is a way to split/carefully cut the seal and replace the old one with the cut at the top.
http://www.expeditionlandrover.info/LRhubseal.htm I am not sure how "correct" this is but looks alot easier than taking the hub off even if you have to redo it a a few years time. |
5th Feb 2019 5:43pm |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 74 |
I did that on an old series... it stopped the leak but I wouldnt have trusted it under any water.
5th Feb 2019 5:45pm |
yes thats true, i think they use some liquid weld.
I suppose its the old if your gonna do a job do it properly! |
5th Feb 2019 5:48pm |
Land Rover agreed to replace the steering servo which was leaking,, and the swivel joint seal. It was only one month out of warranty, but even so they didn't have to do it.
Work is all done and so everything is dry. I heard the salt and grit mix they put on the roads here in winter (Austria) has aggressive chemicals in, which can rot the seals and the mechanic told me to jetwash underneath in winter once a week. |
16th Feb 2019 9:53pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1760 |
It's broadly a very simple job, just time consuming.
16th Feb 2019 11:04pm |
