Home > My Defender > here she is
Page 13 of 26 <123 ... 121314 ... 242526>
razz
2001 Defender 90 Td5 PU Caledonian Blue
And for my next trick , i’ll remove my 3/4 full but leaking tank and put it up top , have ordered some metal to make a cradle and some new pipes too , Christ it was heavy , the wood shelf helped me move it along
Post #755947 3rd Feb 2019 4:52pm
razz
Cool , I can get a galvanised cradle brand new for 70 quid , will remove the two uprights that my piece of wood is on and mount the cradle as low as poss , but high enough so the a frame but don’t hit it and the exhaust may get a cut and re-route too Very Happy
Post #755949 3rd Feb 2019 5:02pm
Weston18
England 1999 Defender 110 300 Tdi DCPU Tonga Green
Nice to see something different. Keep it up.
Post #755960 3rd Feb 2019 5:27pm
razz
Thank you Thumbs Up
A little update , i’ve bashed my original cradle fairly flat and positioned in the back , and it works very well indeed , i’ll Still cut out the little uprights and put the cradle down onto the chassis , i’ll weld nuts into the chassis towards the rear and make a bracket at the front to hold to the bulkhead . Will but n bolt it for ease of removal , the pipes sit well on the back on the tank , 4 easy cuts , spin the connector 180 and plug in . Will use a short piece of rubber to join , will rachette the tank to the cradle . May even get a new cradle one day
Post #756002 3rd Feb 2019 7:15pm
L110CDL
Don't forget to put some red paint on it Wink 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #756384 4th Feb 2019 10:51pm
razz
No red paint left i’m afraid , so a quick coating of yellow n silver Thumbs Up brand new cradle too . Pipes next , when this drys n me rubber pipe arrives
Post #757131 7th Feb 2019 7:37pm
L110CDL
That looks much better Thumbs Up
Has your daughter thought of a name yet Question 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #757192 7th Feb 2019 10:00pm
razz
No name as yet , but the cradle has a proper coat of paint now Thumbs Up
Post #757380 8th Feb 2019 8:13pm
L110CDL
I prefer the red paint Laughing 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #758066 11th Feb 2019 10:25pm
razz
Red paint has been ordered Thumbs Up in the mean time , it’s all piped, wired and tested , all all appears fine , next Sunday is pit day , so i’ve thrown the rest of it back together and if all goes well all the pit , i’ll make it permanent
Post #758992 16th Feb 2019 3:27pm
razz
So today I popped out to test the new tank position and pipe work , the defender minus roof too , it was superb weather , well the tank was ok , but the bulkhead split , turns out a previous owner had repaired with fibreglass filler , a quick patch done , repair panels another day , also noticed a dry bearing noise , the viscous fan housing fan is rather shot , and just to top it off , the steering pump has sprung a leak , more jobs after tomorrow’s pit run
Post #760441 23rd Feb 2019 8:42pm
razz
A superb pit morning , except the lake was a smidge deep and upon filling the cab , I Censored up some relays , I switched her off to have a cuppa , but upon restart , she did not , so al relays emptied , and still no luck , except now she would start , then stop , much head scratching and I pulled the crank speed connector , tip out the water and off we went , this little defender is the mutts nuts , next up , viscous bearing , SKF bearing ordered Thumbs Up I got 5 weeks to fix it , lovely jubbly
Post #760574 24th Feb 2019 4:49pm
L110CDL
I like your version of the " sun roof " off Wink
Great you got her going again and had a great day Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #760782 25th Feb 2019 11:08pm
razz
Hello fella , how is ya ? I grabbed a couple of screens shots from someone’s lake crossing video , you can hear my viscous bearing from quite a distance
Post #760804 26th Feb 2019 8:29am
arran jones
Watch out for the crocs Rolling with laughter
That is beyond deep Bow down
Post #760824 26th Feb 2019 12:06pm
