Home > Puma (Tdci) > Indicators stop flashing |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19660 |
Standard indicators or LED? Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§
19th Jan 2019 7:19pm |
Phid Member Since: 25 May 2018 Location: Dorset Posts: 85 |
Standard. 4pin not adjustable flasher relay
19th Jan 2019 7:30pm |
I would remove, check and clean the earth strap on the transfer box.
If that doesn't do the trick, try a new Relay and go from there and see if that works out. Do you have a Multimeter? If so, that may help diagnose your issues with some testing on the feeds at the indicators. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
19th Jan 2019 7:33pm |
Thanks
So the fact that the hazards are working ok - means theyβre on a different relay? Would a bad earth on the transfer box not affect other electrics? |
19th Jan 2019 7:39pm |
It's the same relay but more current flow with all four indicators flashing.
Earth faults can cause all manor of problems, of varying nature. Were the pins of the relay or holder corroded at all? I would say the Relay needs changing, it seems to not be detecting the 50% load compared to 100% load with the hazard flashing. I'd just check the earth strap as it's free to do. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
19th Jan 2019 8:05pm |
Thank you
20th Jan 2019 12:11am |
