Home > Maintenance & Modifications > The security question again |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Mine...factory immobiliser, factory alarm, aftermarket immobiliser, cuts fuel pump and starter motor, steering lock, pedal lock, acrosss all pedals, doors handles with no key locks, secure bonnet hinges, always park it wedged in so it can’t be towed or dragged out.
I also installed a small two red flashing LED’s in the back, on the window surrounds, puzzles everyone, but a visual deterrent to make someone curious it could be a back up alarm... if the scrots want it, they will find a way, but as much hassle as possible might deter them and they move on to one with less hassle or unprotected. |
19th Dec 2018 3:04pm |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 281 |
Why won't it work? I just ordered one for my 2015 Defender |
19th Dec 2018 5:46pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Thank you all for your comments and PM's
I will note that the gear lever lock is NOT available for the Puma Defenders. 130's have feeling's as well you know |
20th Dec 2018 4:06pm |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 178 |
just fitted an Optimill quick release steering boss well engineered piece of kit
20th Dec 2018 4:45pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
Fit the loudest siren you can possibly find, inside the car. That way if anybody opens any door or Windows the alarm will be activated. It will wake up the dead and with luck cause permanent deafness to the miscreant. Quite apart from which, with that level of noise they won't be able to think, never mind do anything. Yes it's illegal, but I couldn't care less. They shouldn't be inside my car in the first place
23rd Dec 2018 6:29pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
id say fit as many as possible, may be a pain at the time, but you know your defender is more likely to be there when you return.. Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
25th Dec 2018 12:33pm |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 357 |
My 'ardcase and disklok (with extra plates welded on the back) have prevented 2 attempted thefts. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
31st Dec 2018 1:44pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
You have probably found out by now but LR changed the design of the steering column there is nothing to hold the shear bolt...I think someone on here came up with a bodge to get round it ....so they might have pm'd you by now! |
5th Jan 2019 11:18pm |
6th Jan 2019 11:51am |
