Home > Maintenance & Modifications > VCV (Where are you getting yours from?)
Bit of a boring one this as I know as it has been covered a fair few times.
Today my 90 had an erratic idle, which it has for some while but today also cut out whilst cold a few times before I left the drive.
I haven't use it for a few days either, an once warm was fine and as normal.
No MIL so I'm pretty damn sure it's VCV, and likely the orgiginal fitted.
Just wondering, where are most of you getting all of all of yours?
I'm pretty sure most are going Denso and not the £160 odd LR marked up same version.
There are lots on eBay too, but I find it hard to belive such a vast price difference between about £30 and £169 when all seem to be OEM Denso, Genuine or Britpart. (No thank you!)
Finally, info on unclipping the connector and torque for the two fixings would be incredibly useful.
I'm guessing the pump learn will be more a pain than anything else.
Thank you. Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #745355 12th Dec 2018 9:15pm
jst
big thread on this last month, i bought one of Jones from ebay, fitted it and no pump learn. no probs too date. fitting is covered on the thread. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #745371 12th Dec 2018 9:42pm
jst
https://www.defender2.net/forum/topic25121-120.html Cheers
James
110 XS Utility
90 Puma Hardtop
Post #745372 12th Dec 2018 9:43pm
Thank-you. I did search for it but couldn't seem to find the info I wanted.
Did you have a tune at all? This is a point I am a bit concerned about as I've been told not to get a pump learn done with remap loaded. (Alive stage 1.)
Edit.*And it seems a Pump learn isn't always required.* Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #745396 12th Dec 2018 10:42pm
williamthedog
I found genuine landrover on ebay when I needed one last year. Didn't bother doing the pump relearn, bas tune all good Thumbs Up
Post #745440 13th Dec 2018 7:51am
williamthedog
Missed that bit, it's easier to unclip the connector when you've removed the 2 bolts holding the vcv. Thumbs Up
Post #745441 13th Dec 2018 7:53am
Genuine Ford for me, both times. I've done a relearn without removing my BAS tune with no problems, and I've also let it sort itself out over time with no problems.
I would only consider taking the tune off as an absolute last resort, since my EGR has been inactive for 200,000 miles and I seriously doubt it would work if I went back to a standard tune. It would open a huge can of worms!
Post #745445 13th Dec 2018 8:26am
Oh so that’s a relief, I did know trying to load the old map would be a disaster what with the EGR cooler being coked most likely. Already blanked and the EGR that used to throw up the MIL. I guess it must relearn it’s self over time for the pump, when or how often who knows. Most things seem to happen after xx stop start cycles.
Blackwolf - Out if interest and if you could kindly spare the time do you have that P/N for the Ford part?
It’s done quite well so far, likely the original VCV on mine from new in late 07 and nearly 80k so can’t complain. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #745462 13th Dec 2018 10:30am
Forgot to add one last point. Looking at the other thread kindly pointed out above. It appears there is no torque setting the the two bolts and is instead an experienced nip up tightness and not over tight.
Can anyone confirm that there is not a torque setting for these.
If there is I can look it up, only I haven’t had time to check as of yet. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #745465 13th Dec 2018 10:52am
williamthedog
As said, just nip them up, they're only m6 so they don't have to be too tight. I wouldn't think you'd be able to torque them up anyway due to the position of the vcv. Thumbs Up
Post #745469 13th Dec 2018 11:01am
One less thing to bother about then. Thumbs Up
*Edited to save another posting.*
I found the following P/N's when searching on here, which should be useful:
The Landrover part number is LR009837
The Ford part number is 1 514 885 (6C1Q 9358 AB)
The Denso part number is 6C1Q 9358 AB
Glad there isn't much involved and I can just change it over, will have to get one ordered up soon and get on with it. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #745533 13th Dec 2018 5:41pm
jst
no i didnt do a relearn. Cheers
James
110 XS Utility
90 Puma Hardtop
Post #745903 15th Dec 2018 10:40pm
That's good to hear then.
I'm waiting on prices from Ford, just to see what the say really.
The other day I read though various threads on this subject and when I was looking at the PF Jones Denso ones in the 'condition of sale' section tab it does mention if memory serves me right that most parts are reconditioned and tested parts.
The eBay Denso ones look okay, but who knows if they are genuine used or recon or what.
If they do happen to be faulty with no EML who knows if something else could be thought to be the culprit.
Either way, just waiting on prices but I'm imagining Ford would be £130 - £150 by now looking at prices a few years ago and LR are probably about £200 which takes some swallowing that amount for an item such as the VCV.
I find it hard to see how the eBay Denso versions sell for around £60, at other retailers sell for around £110 or so and Ford abd LR above that.
The eBay ones must be recon a lot of them I'd have thought, but who knows. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #745916 15th Dec 2018 11:51pm
