Home > My Defender > My 110 MILLIE. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
Great photos! James
8th Nov 2018 1:20am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10545 |
Thank you James 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
9th Nov 2018 9:21pm |
I picked up Millie from my indy today as she had to go in again for another master clutch cylinder When she went in for her 6,000 mile service they changed it for a new one as the one in Millie was leaking, so i said to my indy is there any better ones and he said the only other one is a genuine LR one, but it's double the price, so i said we will have to give it go, he did say it was a Girling, so hopefully this will cure the problem 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
9th Nov 2018 9:48pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4951 |
yeah not sure what bulbs i had in it before but they must have been causing some problems. But since i have changed the bulbs over and did the same with my dads. Every thing has been spot on. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
10th Nov 2018 2:44pm |
10th Nov 2018 2:47pm |
So as our little group went of green laning on Saturday and i thought that it was best to put this on after, so up nice n early Sunday morning, saw blue sky so it's going to be a good day went out and started my little tasks for the morning on Millie
Before, she is a bit dirty .................... Click image to enlarge So after i had fixed it in the right position, i went around and cleaned all the lights and the number plates ................ Click image to enlarge The poppy is well protected there and out of harms way, but still visible 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
12th Nov 2018 9:48pm |
before what Having your latest fix of Tea and biscuits at graftys.
ah well forget that, you have fixed the post Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
12th Nov 2018 9:55pm |
^^^^ 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
12th Nov 2018 10:52pm |
So after doing the first list of jobs i then turned my attention to the back of Millie, so here is the back before the new addition ...................
Click image to enlarge As i have had the rear facing spot light for a long time, replacing it a few years back for an LED one, is was quite good for when i was up the store getting materials in the Autumn/winter time ( store has no electric fitted ) and reversing in awkward places, i thought it was time to upgrade it as the technology has improved alot, so i got this one ................ Click image to enlarge The price was right, not too cheap but not to expensive and of course it was the right size for the place it was going to be, so the bits that come with it....................... Click image to enlarge Then it was time to go and fit it, the only thing that did not come with it was any type of instructions/info on the light I figured out that the shorter bolt was to attach the bracket to the light and the longer bolt with the nut attaches the bracket to the mounting place, so as i was not pleased with the longer bolt and nut as it was way to small for the hole in the bracket, very moveable, so i got a bigger nut and bolt ...................... Click image to enlarge Then it was to fix it in place and connect it all up and it all went proper ...................... Click image to enlarge Click image to enlarge Protected Click image to enlarge Well pleased with the out come and it is out the way and not to noticeable there Can't wait to see the full effect when it is dark 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
12th Nov 2018 11:19pm |
Neat upgrade that! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
13th Nov 2018 5:18pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Very nice mate. Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
13th Nov 2018 5:21pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19657 |
Liking that. You might want to update the fixings at a later date to Nylon SS perhaps?
And possibly some small closed cell foam tubing split, and zip tied around the wire edge so there is no injury risk, especially in the corners we all know what wire is like. The MOT man is always looking for pointy out bits for obvious reasons. The two light bars I have on mind have been faultless for the price, cannot fault them so I'm sure you'll have great success abd use from it. Only thing is the fixings can tarnish, that's obviously due to SS quality of composition. But for the prices, I don't think that's much to complain about and a few SS fixings costs peanuts. Looks good, keep up the good work. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
13th Nov 2018 5:27pm |
a few mins with the tin snips to take off the corners. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
13th Nov 2018 6:54pm |
Thanks all
There is no need to worry about the MOT guy as he is my indy and has never failed it on those corners 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
13th Nov 2018 10:00pm |
