Home > Technical > a dash that is driving me crazy |
rillas Member Since: 27 May 2012 Location: warilla nsw 2528 Posts: 15 |
thanks all for the comments the short video hit it on the head thinh I will go and buy a set off ear muffs
22nd Sep 2018 1:03pm |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 437 |
+1 for the bonnet hinges. Mine were the same on the Puma. The little nylon inserts were the culprit. I didn’t even to buy new ones I just swapped them over and this cured it. Take the bonnet off and go for a spin and see if the noise goes.
Make sure you don’t lose the little nylon bits tho |
22nd Sep 2018 7:18pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6482 |
Yes where my fingers keep going there is a screw fitted there 1988 90 Td5 NAS soft top
2015 D90 XS SW |
22nd Sep 2018 7:19pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
Have had tho in the past. Only happened over 50 mph or when going round roundabouts. Took me about 3 years to find it. Turned out the a lump of glass from a broken side window, down the front well of the dash, which flexed on roundabouts, and the bulkhead moved with wind pressure over 50. Run a screwdriver or bent bicycle spoke along the well, and see it anything flicks up, a screw maybe?
30th Sep 2018 8:28am |
Thanks I will look in the morning
30th Sep 2018 10:40am |
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1029 |
She looks a lot like Sean Young in Blade Runner... which is no bad thing! |
30th Sep 2018 12:00pm |
YES!
Fixed my squeak completely. Two contributing factors: centre screw fixing and radio cage. The dealership technician had refitted the centre topmost screw (the one my fingers were on in the vid) at an angle, missing the plastic lokut nut and giving a poor fixing. Also, they had evidently removed the radio as part of the warranty work, but did made a mess of refitting. The radio cage was loose, and the radio loose in the cage. Oh and the rubber for the locating peg was missing. So - removed radio, refitted cage securely, found a spare rubber for the rear locating peg. Refitted radio and made sure it was pushed all the way into the cage. Bingo 1988 90 Td5 NAS soft top 2015 D90 XS SW |
26th Oct 2018 2:47pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Its a defender, it should squeak, and creak, and clang, and bang?!?!? NO??
Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
26th Oct 2018 3:28pm |
Absolute bliss now 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Oct 2018 3:35pm |
martin thanks pulled radio out replaced panel still there so I left the two srews out went fo drive over rough road no squeck so I put upholstery pins PERFECT no more mouse sorry did not need mouse trap
31st Oct 2018 10:01am |
I cant imagine what its like to drive a Defender with no rattle - Its weird enough in my wifes corsa - almost too quiet for me now.. Only had my Defender since May, in the beginning all the knocks and bangs were worrying(coming from a pampered Audi with no noise at all) but I love all the noise it makes now! Regards
31st Oct 2018 11:55am |
