Home > Puma (Tdci) > Sticking throttle ,but not
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Hi , I done a 400 mile trip on mostly motorway at the weekend and on return home the throttle seem to stick for 2 or 3
seconds . As it is a cableless throttle is it a sensor somewhere ? Last night i disconnected the battery for half a hour which cured the issue for now ! Does anybody have any idea what the problem was as i dont want to get stuck in the middle of no where in limp mode or worse.
Forgot 2010 usw puma tdci 48000 miles standard engine
Post #653018 26th Sep 2017 8:25pm
Thon
Check your brake light fuse. It is one of the common causes for this "sticky throttle" behaviour.
Don't ask me why, but it is.
Another possibility is the clutch switch, which can simply be shorted out in the loom plug (I used a bent paperclip).
Post #653026 26th Sep 2017 8:55pm
The connectors for the clutch switch should it be that are called J.P.T. (Junior Power Timer.) connectors.
To bypass simply crimp a wire loop in on a male connnector as a bypass with some pins.
Totally reversible and easy to do.
Mine is bypassed also, and never had an issue.
It's still worth checking the brake light fuse though as suggested. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #653034 26th Sep 2017 9:14pm
Outlaw1
Thank you for your quick reply Thon I had forgot that at the same time i disconnected the battery , also changed the fuse for the brake lights. Thinking this is a coincidence and not a connection ( no pun intended )Very strange .
Post #653037 26th Sep 2017 9:36pm
Outlaw1
Thanks .Where is the clutch switch ? Thumbs Up
Post #653043 26th Sep 2017 9:49pm
D90LANDY
Czech Republic 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Could you post a photo of exactly how you shorted/looped the plug? I'm keen to try this but don't want to get it wrong. Thank you!  2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #735230 17th Oct 2018 9:32am
If you PM me it’ll remind me and I’ll find it, I have a pic but not on my phone.
It’s very simple, and works well and completely reversible. Ideally you should have a device to read and clear DTC codes if needed thought.
It’s never caused an issue or put on the MIL for me and been better for it!
It can log a DTC but it won’t do anything and I just clear it.
Runs much better and nice in all gears especially low range, and importantly anti stall works perfectly and more sensibly too. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #735247 17th Oct 2018 10:34am
D90LANDY
It sounds good to me. I've got a DTC device so that side of it is fine. I look forward to the photo.  2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #735254 17th Oct 2018 11:29am
D90LANDY
Just writing another post as I need three posts to PM you. Let's post the photo publicly when it's sorted as it may well help others out. Excited to try it out!  2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #735258 17th Oct 2018 11:35am
Martin
Site Admin
http://www.defender2.net/forum/post641429.html#641429  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #735271 17th Oct 2018 12:32pm
D90LANDY
Thanks Martin - that's essentially what Steve just PM'd me, happy days. Thanks for finding that.  2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #735272 17th Oct 2018 12:35pm
Porny
Site Sponsor
Other option is to reclaibrate the ECU properly, which when done virtually eliminates rev hang.
And I don't just mean a generic remap...
Personally I would leave the low range idle jack in place - its there for a reason.
Just need to make sure your clutch switch is working correctly. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #735273 17th Oct 2018 12:51pm
D90LANDY
This Defender has a remap so it is indeed possible to get this 'feature' added.  2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #735275 17th Oct 2018 12:53pm
Porny
Site Sponsor
Not by me it's not... as I have no interest in correcting other companies work. Also, a warranty problem from my point of view.
Not sure anyone else has worked out how to do it yet.
2.2 is done - just finishing off 2.4 IRB
Post #735277 17th Oct 2018 12:56pm
D90LANDY
Hi yeah, I didn't mean you doing anything with this vehicle.  2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #735279 17th Oct 2018 12:59pm
