Home > Technical > TB for fuel tank breather |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5029 |
Yes but to relocate it behind the light panel flap. I cant see why this wouldnt work, i suppose unless you went deeper than it? Mike |
15th Feb 2009 8:31pm |
Tony_Hillerby Member Since: 03 Feb 2008 Location: Inverurie Posts: 36 |
My 110 has had another ride on the back of a recovery truck. It started to make strange engine combustion noises when changing gear and accelerating away again, mostly from cold. It was also starting to get a bit shaky when starting up from cold. The dealers will be looking at it next week so we will see what happens.
15th Feb 2009 9:45pm |
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 |
i have relocated my one behind the rear panel but that was about novemeber last year tect said they pull so much crap in the tank should have been drained last year and the fuel lines flushed through no wading ever done in my one
dealer as just rang did i fill it up with petrol i will keep you posted |
16th Feb 2009 9:35am |
Just had a word with the dealers and they have replaced I think the pressure relief valve and also said that there was again water in the diesel. Last year I had the same and had the injectors , pump and fuel rail changed and the breather re located behind the flap at the rear of the wheel arch.
So tank drained and new filter fitted and system flushed out. I have not been wading or off roading as its a tow vehicle for the caravan and LR trialer. Does this mean that the official fix does not work. I have seen pictures of extending the breather but does this mean if I do this myself that will affect any future warranty issues on the fuel systems. Tony |
18th Feb 2009 11:47pm |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 281 |
Any more information on how to do the breather pipe relocation behind the light panel guys?
Cheers Rich |
19th Feb 2009 9:29am |
its back
i moved the breather pipe in november last year so it had been sucking water for over a year so the tank had loads of crap in it dealer did not carry out the TB problem is the pump is engine mounted not in the tank as the TD5 it had two. so the tank breather is pulling more air all the time it may mean the TDCi is more Prone to water in the fuel Than the TD5 some could be coming from the pumps as well dan |
19th Feb 2009 10:10am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
I have it.
But not idea how to post a PDF here PM me if is still needed. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
19th Feb 2009 1:03pm |
thanks eduardo i have it now it still not right very noisy from the top of the engine after it came back |
19th Feb 2009 10:24pm |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 |
Very simple - unclip it from it's position behind the passenger side rear wheel inside the wheel arch, lift the base of the black plastic flap that shields the passenger side rear lights, and push the tube up the LHS (looking to the back of vehicle) behind the plastic flap. |
24th Feb 2009 6:35am |
Thanks very much for that, I'll give it ago this weekend, just one question though. Does doing this allow fuel fumes to enter the vehicle? |
24th Feb 2009 9:01am |
No - not at all - the area where the breather is placed is still outside the vehicle's interior. |
27th Feb 2009 5:45am |
