Home > Technical > 10mm+ shim wheel spacers?
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
https://www.ebay.com.au/itm/CXRacing-5x6-5...2801960369
Is there anywhere in the UK which sells shim type spacers for the defender?
I'd like to run 285 75 16 on some boosts but Blackwolf had pointed out, with 30mm spacers they'll throw mud down the sides my 90 even with gwyn lewis mud flap extensions.
I think there's enough thread to safely run 10mm, although 15mm might be pushing it. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #731915 29th Sep 2018 10:15pm
Kit
Found these: 120 inc VAT: http://www.wheelspacers.uk.com/product_inf...amp;typ=LD 1993 200 Tdi 90 CSW
Post #731916 29th Sep 2018 10:48pm
Roy5695
Fit some Dirt-defenders too. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #731921 29th Sep 2018 11:16pm
Kit
Yep, I have those for the rear Thumbs Up 1993 200 Tdi 90 CSW
Post #731922 29th Sep 2018 11:22pm
bankz5152
Spacers like that can be dangerous. Fit eider mud flaps. Instagram @defender_ventures
Empire Tuning - Agent
Post #731928 30th Sep 2018 6:49am
Grouse
If you fit longer wheel studs though they are safer than normal spacers Thumbs Up
Post #731931 30th Sep 2018 7:39am
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Eider mud flaps sound posh but doesn't the down get soggy ? Wink
Post #731933 30th Sep 2018 8:05am
Kit
Yep exactly my thinking, with some 60mm wheel studs Thumbs Up
+ I already have gwyn lewis mud flap extensions 1993 200 Tdi 90 CSW
Post #731976 30th Sep 2018 3:12pm
Kit
I've also emailed these guys:
https://www.superforma.co.uk/wheel-spacers...pacer.html
http://www.rakeway.com/
If anyone else would be interested in some 20mm bolt on or 15mm slip-on (to be used with 60mm studs), let me know 1993 200 Tdi 90 CSW
Post #731978 30th Sep 2018 3:34pm
With the size of LR tyres and wheel arches, I'm not sure that 10mm is worth the effort. I think I'd struggle to tell the difference Confused Darren
Post #731990 30th Sep 2018 4:45pm
Kit
I don't disagree, in order of my preference:
Ideally i'd like a set of 20mm hub-centric spacers
15-20mm slip on spacer with 60mm studs
10mm slip on spacer with normal studs 1993 200 Tdi 90 CSW
Post #731994 30th Sep 2018 5:15pm
I was always led to believe that 30mm was the minimum thickness of bolt-on spacers due to the thickness of the LR wheel nuts and the need for there to be enough metal beneath them for adequate strength. Darren
Post #731998 30th Sep 2018 5:29pm
NickMc
The only thing wheel spacers do in my opinion is kill wheel bearings faster Whistle
Post #732020 30th Sep 2018 6:42pm
Kit
I'm not sure, they make hubcentric 20mm spacers for V8 diesel landcruisers and plenty of high power cars? I guess you have to use some common sense, if you're going to be towing 3.5T regularly or youre going to be loaded down for an expedition, then you don't use spacers at all.
My 90 is just a restoration project that'll see light use, maybe some light/medium green lanes. 1993 200 Tdi 90 CSW
Post #732029 30th Sep 2018 7:17pm
DSC-off
If want to do 70mph occasionally with wide and heavy 33" mud tyres, that are notoriously hard to balance, then spacers may not be a good idea for that either!
Post #732035 30th Sep 2018 7:50pm
