Home > For Sale & Wanted > [Wanted] Roof trim for Military Escape Hatch
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
Many years ago I bought a water damaged but BNIB and Land Rover branded Military Escape Hatch (essentially a sunroof with an aluminium panel instead of the civvie glass) which I have only recently fitted. But it turns out the water damaged packaging hid the face that the inner roof trim was missing! I do have the rubber seal to go between the runroof and the black plastic roof trim though.
So now that I am fitting a new headlining I desperately need to find one of these roof trims!
What doesn't help is that the military hatch has differently spaced locator tabs ('hinges') to the civvie glass sunroofs so I need to find the correct part!
Post #718003 16th Jul 2018 12:17pm
JR
BUMP!!
Post #730330 21st Sep 2018 3:17pm
JR
An alternative option might be to get one 3d printed, could anyone help with that?
Post #730331 21st Sep 2018 3:19pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Not sure what you mean by the inner roof trim ? Do you mean the panel that sits on the inside or the rubber strip thing that clips in and covers the edge of the roof lining ? http://www.yorkshireoffroadclub.net/
Post #730352 21st Sep 2018 5:13pm
JOW240725
Photos might help? James
Instagram @suffolk_rovers
Post #730366 21st Sep 2018 6:38pm
JR
The plastic trim panel that holds the edge of roof cloth is the part that was missing from the kit when I bought it.
I actually have 2 of the rubber spacer strip as I bought one recently that I thought was the plastic panel based on the description!
I fully understand the confusion as this 'escape hatch' is hardly a common fitment! As for a photo (JOW240725), I have never managed to figure out or understood how add photos to my forum posts, I really am just pretending how this forum stuff works!! Embarassed Embarassed Also, whilst I have the actual 'escape hatch' fitted, I haven't wanted to fit the new head lining until I have the last bit of the jigsaw (the plastic trim finisher) so that I cut out the right size and shape of hole without ruining the new head lining!
Post #730380 21st Sep 2018 7:15pm
davew
I don't recall a plastic trim, there's just a shaped rubber finisher that pushes out around the head lining and clips into the aluminium internal frame covering the screw heads.
This is a pic of one of mine with everything in place:
It's not the clearest pic but most of the black area to the outside of the unit is a kind of rubber seal that has a weird texture, like a velvet feel to it. I can try and get a better pic of it later, I'd remove it but it's a real PITA to get clipped in again ! It comes as one long length and you have to form it as you fit it, especially in the corners. It may actually be the same as the glass version ? http://www.yorkshireoffroadclub.net/
Post #730423 21st Sep 2018 9:20pm
JR
But your pic shows the very same plastic trim that I'm looking for!
Post #730426 21st Sep 2018 9:28pm
davew
No plastic there at all that I recall, just an aluminium internal frame (painted black) and a rubber trim/filler piece. http://www.yorkshireoffroadclub.net/
Post #730431 21st Sep 2018 9:34pm
JR
I have the aluminium finisher that is attached directly to the underside of the roof and that screws directly to the 'escape hatch' and I have a rubber spacer that will fit to the aluminium finisher attached to the roof but this cannot attach to the headlining.
What I am lacking is the wide black bit, I thought it was plastic, that attaches to the headlining and which keeps the headlining at the same distance from the roof as the bit of white trim that is fitted on the inside of the actual hatch (the bit on the photo that the net 'pocket' is fitted).
The rubber spacer that I have has nothing to attach to the vehicle's headlining as opposed to the panel attached directly to the hatch itself.
Post #730452 22nd Sep 2018 12:44am
davew
OK, that's actually a rubber strip, I have a feeling I might have a spare one of those and I think the same is used on a normal sunroof but could be wrong.
I'm competing at a trial tomorrow, not sure when I'll be back, but if I get back early enough I'll have a dig around in the garage, if not it'll be Monday. http://www.yorkshireoffroadclub.net/
Post #730553 22nd Sep 2018 8:56pm
