Home > Maintenance & Modifications > Toyo Open Country MT 255/85 16 |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Thanks for your report!
I like your new boots ! Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
14th Aug 2018 11:27am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Great write up, thank you. For the money they seem amazing! I shall be getting a set when the rims come in stock!
What a great camping Defender James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
14th Aug 2018 11:09pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3464 |
Did 150 miles across wet and boggy sand today. Can’t fault them. They clear their treads quicker than my MTR’s did. 1951 80" S1 2.0
15th Aug 2018 6:41pm |
Wet and boggy! That I wouldn't expect, I'd imagine dry dry dry. James
15th Aug 2018 8:39pm |
We planned for dry hot dry and more heat. Most days we have had some rain but Tuesday evening and Wednesday the Sahara region has had flash rains. Normally 4 inches per annum, they have had 6-8inches in 36hrs. We have failed to cross some ‘dry’ river beds as it was so deep and fast flowing that we picked our way north away from them. So wet and boggy sand was a fair description. I must hold the record of the only UK Defender owner to have his wipers on for 6hrs in in the Sahara in August 1951 80" S1 2.0
16th Aug 2018 8:05am |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 |
I've got the same Toyo tyres on my Wolf...they are fantastic & frankly a bargain, I paid £88 each inc fitting at my local tyre fitter.
Click image to enlarge Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
16th Aug 2018 9:52pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Where was that fat cog, the cheapest I can find is £101 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
17th Aug 2018 12:20am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1333 |
130 looking belting
17th Aug 2018 6:03am |
I got them from Protyre in Banbury; I've just looked at my bill dated Feb 2018 and they were £82 + VAT each including fitting but I had a discount code which took them down to £89 each all in. When I got them the fitter said they hadn't supplied them before so I think they were heavily discounted, i've just checked their website & they're up to £115 so I think I was lucky. Having said that, I'm so impressed with the tyres that I'd happily pay that, especially looking at the price of BFG's, Bridgestone 's etc. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
17th Aug 2018 8:37am |
Just under 5000miles completed.
Still incredibly impressed with these. Messed around with tyre pressures from 32 upto 50psi in the rear of the 130. Noise changed noticeably with the greater contact patch and less pressure. She seems happiest with around 45 psi in the rear. The ride quality is good. Dry fast road grip and braking predictable. I could get the Goodyear’s to lock quite quickly in the wet but these strubbornly refuse at the same speed. Looks wise (if that bothers you) they are aggressive and look great in my view. The only downside is slow moving first gear traffic where you can feel the tread blocks vibration slightly. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
26th Aug 2018 6:44pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
Lovely wolf! |
30th Jul 2019 6:59pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1778 |
And good for 16x7" rims I guess Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
30th Jul 2019 8:50pm |
Do they compromise the turning circle noticeably compared to 235's? Seriously thinking of putting a set on my 300tdi on Zu's (which are ET11 I think) as the 235 AT's look a bit 'lost' in the arches
31st Jul 2019 1:38pm |
doncarloz Member Since: 29 Oct 2017 Location: Styria Posts: 60 |
I'm running the same size (bfg mts) on ZU rims and tbh the turning circle didn't get worse alot. Just adjust the steering stops and you should be fine.
31st Jul 2019 4:51pm |
