Home > Technical > Torque converter issue? |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
The spigot bearing bush comes out.
Speak to David Ashcroft about the transfer-box linkage. I bought the whole auto conversion from him for my 300TDi and yes it did come with a different linkage for the HI / LO / Lock. ONE LIFE, GET IT! |
4th Aug 2018 8:03pm |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 305 |
Hi,
Generally speaking: The input shaft on a manual transmission does not always go round when the engine is running. Therefore you need a bearing in the end of the crank with a manual transmission. With an automatic transmission the torque converter always goes round at engine speed and is bolted to the flex plate on the back of the crank. Therefore you don't need a bearing. I don't know specifically about your engine, but I just assumed all engines now have proper bearings, I haven't seen a bush in the back of the crank since the mid seventies era. If you have a bronze bush then measure the inside diameter, if the nose/spigot on the converter don't fit then remove it. Probably best to remeasure with the bush removed to see if the converter then fits nicely. Do you know how to get the bush out? Bob |
4th Aug 2018 8:09pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7688 |
I had the same with my conversion, I removed the Bush by collapsing it. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
4th Aug 2018 8:43pm |
By diff lock linkage do you mean the housing adaptor it needs to mount the lever? If so it's a std or part. Cheers
4th Aug 2018 8:44pm |
iceshj Member Since: 16 Jan 2016 Location: Southampton Posts: 28 |
Thanks guys, you have confirmed my thoughts. I will pop the copper/bronze piece out. The bit for the diff lock is the linkage that the lever piston is attached to that fits down onto the torque converter. Looks like a piece of Ali folded in half,
Thank you Defender 90 softop (in bits) Range Rover Hybrid SVAutobiography Discovery 3 HSE Kawasaki ZX12R |
4th Aug 2018 11:32pm |
