Home > Maintenance & Modifications > Puma master cylinder / clutch.
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Put a new clutch / slave in the 110 ( clutch fix off Brendan) Problem I’ve got is that when warm / hot it’s tight with the gears mainly 1st and reverse. It’s been bled by me every way possible, and after a few days the fluid seems to have a black tinge to it & looks like oil. The master isn’t leaking & as said cold it’s fine! Thinking of changing the master as I can’t think of anything else.....Thoughts?
Post #721369 4th Aug 2018 8:45am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
This happened to my 07 Puma it was the seals breaking down in the M/C.
Post #721378 4th Aug 2018 9:42am
Timcat
Ahhhh that’s good to know, thanks for the reply. Did you replace it with a genuine one or a pattern part?
Post #721392 4th Aug 2018 11:34am
