Home > Technical > water ingress
sjc501
water ingress
Hi I have water running down my accelerator pedal when it rains .Anyone had this before .2013 Puma 110 . Only just started.
Post #718163 17th Jul 2018 7:54am
familymad
Rain?
Whistle 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #718164 17th Jul 2018 7:58am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
OP does have Glasgow has a location, it rains most days Rolling with laughter . Keith
Post #718170 17th Jul 2018 8:43am
donmacn
Re: water ingress
I think part of the issue on the forum here is that this is such a common and well-discussed topic. A good and thorough search will find lots (and lots) of threads about this.
I think it's good advice to find a copy of the water ingress manual and go through that. Another part of the problem is that water leaks are just hard to trace because the stuff is so damn ....fluid! It comes in one place, and emerges somewhere else a relatively long way away.
But, in that area I'd consider:
the seals behind the windscreen/bulkhead connector blocks;
the foam strip between the windscreen frame and the bulkhead;
a roof leak that's allowing water to run down the A post;
water getting in where the door seal bends by the wing mirror...
I'm well-used to water leaks - but it's an older car. I sometimes found that where the water would emerge, or how much would come in, would depend on how the car was parked if there was a slope. Front up? rear up? one side higher than the other...?
But really, there's loads of stuff on here about leaks. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #718179 17th Jul 2018 9:31am
Caterham
water ingress and corrosion are well known issues.
my understanding is that the most comprehensive solution is Africa.
Thumbs Up good luck.
Post #718181 17th Jul 2018 9:40am
sjc501
water ingress
Thanks for replies. Sounds like it could be a multitude of things .I just found it a bit strange it was coming down through pedal
Post #718184 17th Jul 2018 10:03am
williamthedog
I'd go for windscreen blocks or bulkhead seal as said above Thumbs Up
Post #718186 17th Jul 2018 10:15am
Caterham
what about the gasket that sits under the plate that gives access to the clutch adjustment?
....that said if it's the accelerator I'd also go for the window blocks / windscreen foam strip.
not sure if anyone has done this but I've often thought a bead of silicone of silcafix (or whatever it's called) would be a better option to the foam strip?
Post #718189 17th Jul 2018 10:26am
ibexman
Post #718193 17th Jul 2018 10:36am
Caterham
I see that's only volume 2. Rolling with laughter
Post #718194 17th Jul 2018 10:38am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
that foam strip is poor at best I masked my and sprayed wax on it . as said check your window blocks and windscreen seal and door seal
Post #718195 17th Jul 2018 10:40am
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Argh, the foot spa non-optional extra Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #718212 17th Jul 2018 1:45pm
