Home > V8 > Can I use ... |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1542 |
not recommended
14th Jul 2018 2:56pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2089 |
Any reason why not MDM ?
Mo The Land Rover 90 - Many are called, few are chosen. |
14th Jul 2018 3:37pm |
if memory serves me its down to 2 things .
micron filter numbers are different for petrol to diesel to remove impurities and debris etc. diesel filters are meant to take water out of the fuel.some have drain plugs for this some don't. i suspect the internals will be similar or certainly have been on ones we have cut open. on some of the old army landies we have weighed the new filter full of fuel and the old filter and there is a difference as the used one is always heavier. is there a reason why you want to use the wrong filter? |
14th Jul 2018 3:51pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 909 |
My 4.2 90 ran a boy racer filter off eBay sytec filter on the inside of the seatbox worked fine with me.
Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
14th Jul 2018 4:09pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
https://bearmach.com/fuel-filter-br-0272k
This kit comes with fittings, and is what's used on the Defender 50th 4.0L Goes between tank engine on HP side; (normally on the chassis. https://www.roverparts.com/resources/video...fender-90/ |
14th Jul 2018 5:19pm |
Thanks chaps 👍
I was just asking because it's there already but as it doesn't seem suitable I'll explore the other avenues suggested. Many thanks Mo The Land Rover 90 - Many are called, few are chosen. |
14th Jul 2018 8:32pm |
