Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 2 of 31 <123 ... 293031>
1 - 2007
2 - 2.4
3 - yes it's the original
4 - 225k miles
5 - n/a
6 - n/a
Note: thoroughly lubricated with MoS2 grease at 150k miles when last clutch change carried out, at which time it was a better fit than the brand-new spare I had bought just in case.
Edited to add: vehicle operates near GVW for 90% of the time, and is used for occasional heavy towing. It doesn't have an easy life! Also answer to Q3 corrected (I had mis-remembered it as asking "has the shaft been replaced" (no it hasn't) and not "is the vehicle on the original shaft" (yes it is)). My apologies for any confusion.
Post #717276 12th Jul 2018 10:29am
UtilityTruck
2, 2.2
3, Y
4, 59,000
I don’t tow, the vehicle is usually lightly loaded. 2014 Keswick Utility 2.2
Post #717280 12th Jul 2018 1:20pm
JOW240725
1, 110SW 2012 Novemeber
2, 2.2
3, N
4, 1st shaft replaced 05/01/15 mileage unknown prior to ownership.
If the shaft has previously failed, please answer 5 & 6.
5, N - genuine LR parts
6, failed again June 2018 57k miles. Replace with genuine LR part.
Occasional towing. James
Instagram @suffolk_rovers
Post #717298 12th Jul 2018 2:38pm
PumaPhil
Wales 2015 Defender 90 Puma 2.2 HT Aintree Green
1. 2015, 90
2, 2.2
3, Original shaft
4, currently on 64'000 miles
About a third of those miles are heavy towing both on and off road, but I do drive with mechanical sympathy. Can see rust stain so will likely change to Ashcroft shaft and new clutch soon.
Know of someone who used to change his Defender 90 every 12 months with 35-40'000 miles on them. Every year from '09 - '15 (so 6 Defenders). Every single mile was fully loaded with tools in the back and was towing - sometimes in excess of 4 tons (on private roads....). On and off road. Driven hard and not one single mechanical failure. In fact they were some of the nicest Defenders I've driven, really 'run in' after 12 months!
Post #717307 12th Jul 2018 3:34pm
Noiseydave
United Kingdom 2009 Defender 110 Puma 2.4 XS DCPU Santorini Black
1, 2009
2, 2.4
3, N
4, 65k
5, Y
6, 71k
Post #717308 12th Jul 2018 3:36pm
diduan
Bulgaria
1, 2011
2, 2.4
3, N
4, 80 000 km
5, Y
6, 102 000 km Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #717310 12th Jul 2018 3:47pm
Landumph
England 1993 Defender 90 V8 Petrol HT Arles Blue
1. 2011
2. 2.4
3. No
4. 25k
5. Genuine Parts fitted by main dealership
6. Don’t know, sold it
Post #717315 12th Jul 2018 4:23pm
Blondie
2. 2.2
3. Original
4. 25k miles
No towing, mainly driven on road.
Post #717329 12th Jul 2018 5:35pm
desender
Scotland 2007 Defender 90 Puma 2.4 CSW Stornoway Grey
1, 03/2007
2, engine type 2.4
3, is the Defender still running with the original output shaft? No
4, vehicle milage at first shaft failure. 84.000 ish Shaft did not fail, but had it replaced when I had the clutch done. According to mechanic the shaft was about to fail.
Post #717332 12th Jul 2018 5:48pm
lohr500
1: 2012
2, 2.2
3, Y
4, 19,500 miles
Post #717335 12th Jul 2018 5:58pm
nosnibod
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
1, 2015
2, engine 2.2
4, Changed at 52,000, shaft was very well worn. Dave
Gracie - 2015 110 XS County Station Wagon
Post #717338 12th Jul 2018 6:22pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Output shaft failure, Forum Survey
DSC-off wrote:
1, vehicle year of manufacture
2, engine type 2.4 or 2.2
3, is the Defender still running with the original output shaft? (Y/N)
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running.
1 - 2012
2 - 2.2
3 - N - replaced with Ashcroft kit
4 - 40K (miles) - failure on holidays in the Alpes mountaines
So much data - is going to help us understand what's going on Thumbs Up
Post #717375 12th Jul 2018 8:59pm
Thon
2, 2.4
3, Yes
4, 59K
Driveline suffers backlash, no rusty dust from drain hole so suspect clutch (rattly) and diff(s).
Output shaft will be swapped for Ashcroft when the clutch finally disintegrates.
Post #717383 12th Jul 2018 9:13pm
Mwd
1, vehicle year of manufacture: 2012
2, engine type 2.4 or 2.2: 2.2
3, is the Defender still running with the original output shaft? (Y/N): N
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running.: 62,444
Shaft replaced with genuine parts by LR dealer.
Post #717398 12th Jul 2018 9:54pm
Siwynne
2. 2.2
3. N
4. Replaced at 40,000 with og LR parts by dealer during clutch change for death rattle under warranty
5. Now on 61000
Post #717405 12th Jul 2018 10:02pm
