Home > In Car Electronics > Defender dash cam
leeds
Defender dash cam
What is the best way of hiding the cable across the top of the windscreen?
No room behind headlining.
Is it possible to glue the cable to the windscreen rubber? If so what glue is recommended?
Thanks
Brendan
Post #717014 10th Jul 2018 1:42pm
grafty99
I tucked mine between the headlining and windscreen rubber so it isn't actually behind the headlining but between it and the rubber Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #717018 10th Jul 2018 2:00pm
JWL
I've just fitted a usb socket fitted in a pod inbetween the internal mirror and the interior light. It is a little bulky but works well, I took a power feed from an ignition fed feed, up the passenger A post and earthed through the interior light earth. I used the short patch lead supplied with the camera, put the ferrite jobby on it and the job's a good one.
If I want to transfer the camera to another motor I can just pull the cable out and dig the cigarette lighter plug lead and do it.
Post #717020 10th Jul 2018 2:14pm
gilarion
I did the same positioned the dash cam behind the rearview mirror, ran the cable between the headling and windscreen rubber then down the plastic windscreen finisher trim then behind the dash with the connector coming out at the side of the heater control panel where the cig lighter is. On the Puma, it is a bit of a fiddle having to remove a few dash parts. But on TDi's and TD5 it's a doddle. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #717021 10th Jul 2018 2:15pm
leeds
I am struggling to get the cable up behind headlining as it feels solid when using a trim tool.
A blob of clear or black silicone onto the rubber??
Brendan
Post #717024 10th Jul 2018 3:16pm
rallysteve
Brendan,
Assuming you dont have a roof console if you loosen the sun visor screws and remove the three screws holding the rear view mirror plate in place, it will be a bit easier to tuck the cable between the headliner and rubber.
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #717025 10th Jul 2018 3:19pm
zsd-puma
I fitted a mud stuff roof console and fitted a USB power socket into it just above the rear view mirror - job done.
Post #717029 10th Jul 2018 3:38pm
VeeTee
Netherlands
rallysteve wrote:
Brendan,
Steve
Indeed, there’s room enough for the cable behind the headlining, but you have to take of the sunvisors and rear view mirror clamp to pull the headlining a bit down. I even fitted a 12 to 5 V converter with usb socket behind the headlining to power the dashcam. The converter (small sized like a box of matches) is fed from the ignition live, this cable runs behind the a-post trim to behind the headlining. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #717031 10th Jul 2018 4:08pm
Mine runs above the headlining, there is plenty of space, it's just not easy to get to. I have a Mud console and the cables exit through the hole where the cab light used to be.
Post #717051 10th Jul 2018 6:10pm
gilarion
If it’s any help I recall that I used one of those flexible electrical wire feeder rods, first removing both of the fir trees above the driver’s door, and then feeding the rod and wire from that location and a hook type tool that I squeezed under the headlining behind the rearview mirror to fish out the end of the rod with the wire attached. In fact, the feeder wire rods that I bought some time ago from Aldi have been used quite a few times on my Defenders to route wires. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #717058 10th Jul 2018 6:56pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I ran mine up the windscreen on the passenger side from the new glove box (where I have fitted a USB point) and then under the sun visors held in place with some large elastic band under the little document holder ... works well and tidy with out disturbing the linings Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #717065 10th Jul 2018 8:01pm
wyvern
sorry no pictures ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #717066 10th Jul 2018 8:01pm
bankz5152
Re: Defender dash cam
Thanks
Brendan
Question Question theres plenty of room. Mine runs from there into a piggyback off the fag lighter. Instagram @defender_ventures
Empire Tuning - Agent
Post #717090 10th Jul 2018 9:35pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
For me it was an arse to get it pull the headlining down a bit and hide it under there. I'm good with the spanners but mine refused to bend enough to allow access.
SO - I pulled the windscreen rubber and tucked it between that and the glass. You wouldn't know its there and worked a treat.... going along to the passenger side, down through and behind the plastic a piller cover, and into the back of the stereo for power (positive to radio live / ignition live to radio amplifier remote {blue cable} end earth to radio earth)
couldn't be easier! 1953 80"
1987 mini city e
2011 90"
Post #717227 11th Jul 2018 10:01pm
bluebottle
I thought about this and decided not to bother. Bought a Garmin satnav with built in dashcam.
Post #717238 11th Jul 2018 10:55pm
