Home > My Defender > What Did You Do In Your Defender Today |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Wondered why the bumper and grills had been taken off a respray explains why. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
20th Jun 2018 4:11pm |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 |
Today I went to Blenheim Palace to place some generators around the grounds for lighting for flower show that's this weekend and was asked to fit a flashing light,and few months ago I went down to Mersea Island and towed some caravan about on one of the camp site's ,because it's a public area I had to have a flashing light.Where to fit one ? This was my solution was mount a steel plate on top of the RAI .Seems to hang on OK up 60mph .
Click image to enlarge Click image to enlarge Click image to enlarge Then went for a drive around the park Click image to enlarge Click image to enlarge |
20th Jun 2018 5:20pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
I need to find out where I get one of those. Keith
20th Jun 2018 7:26pm |
Years ago when escorting farm kit around the roads I glued an old magnet off a cb mag mount on the underside of my Ifor Williams top making sure the thing was the right way round to attract the magnetic mount on the flashing beacon I used. It was quite impressive to just stand by the side and just chuck the flashing light on the roof and it would "find" its spot every time. It used to take some prising off mind
I'm sure it would be simple enough to glue a similar magnet under the roof lining to do a similarjob |
20th Jun 2018 9:34pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Yesterday;
Replaced rocker gasket Front cam seal Oil change; Axles F&R, gengine oil and filters plus air filter. Changed fuel filter. Snapped one of the bolts holding the rocker cover in place, managed to remove this and replace with spare Did the transfer case and then regretted doing it. Noticed the drain plug was not very tight....on removal, some of the threads are damaged Managed to get a fix but a more permanent one is required. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
22nd Jun 2018 10:21am |
Took my daughter to a Jamboree Scout camp for the weekend and took a quick snap on the way out:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
22nd Jun 2018 9:45pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
I bet that lane gets a tad muddy in the winter 😬
22nd Jun 2018 9:53pm |
Today just keeping out of the sun
23rd Jun 2018 8:09am |
Fitted spring isolators to the rear of the 110. Gave around 20mm lift. Will see how they go after a few miles of driving. 1999 Defender TD5 110
23rd Jun 2018 8:08pm |
Which isolator did you use? The ones I found were only a rubber sleeve for the back which didn’t lift it more than a couple of mm. Ray
23rd Jun 2018 9:46pm |
These ones
https://www.ebay.co.uk/itm/LAND-ROVER-DISC...2749.l2649 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
23rd Jun 2018 9:48pm |
Have you got any pics of the fitting? Those should be too small for rear 110 springs Darren
23rd Jun 2018 9:51pm |
I didn’t think they made that type for rear defender springs Ray
23rd Jun 2018 9:54pm |
No pics taken - sorry.
I thought they fitted OK. Certainly fitted in the top spring support OK and then spring appeared to sit OK around/below the ring. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
23rd Jun 2018 10:03pm |
