Home > Maintenance & Modifications > Defender 110 Rear Brake Pad Thickness
Grannville
Now then,
Im trying to be a good chap and replace my brakes on my 110 utility. Easy enough. Especially when the hardest bit seems to be working out what thickness rear pads i need. 15mm or 18mm. Can anyone save the hassle of stripping and measuring the caliper gap?
my VIN is SALLDBA576A722***
its a 2006 110 Utility
Many thanks if you can save me double jobbing it!
Post #712494 15th Jun 2018 6:50pm
bankz5152
Either fit afaik if ya worried fit the smaller ones. Instagram @defender_ventures
Empire Tuning - Agent
Post #712533 15th Jun 2018 9:37pm
Thicker ones definately DON'T fit early calipers.... later calipers you can fit the thinner pads... but then you're running around on "new" half worn* pads...
* Ok..maybe not "half" worn... but not the full thickness available.
I've had too many G&T's and VRB's to look it up and coherently type a readable reply...
Post #712550 15th Jun 2018 10:35pm
