Home > Off Topic > My RRC project
Page 24 of 53 <123 ... 232425 ... 515253>
grafty99
1990 was the first year with ABS. The year that mine is Rolling Eyes
I will get to the bottom of it, just a matter of time Laughing
Won't be taking the bulb out procta - it will fail it's MOT for sure Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #712153 13th Jun 2018 7:39am
Procta
shame you could have played the it doesn't have it installed card.
Id check the sensors and wiring on the wheel end, just in case there is a bit of crap. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #712224 13th Jun 2018 6:05pm
grafty99
I've checked everything there is to check. There aren't any fault codes stored on the ECU. Strangely enough when you check the fault codes you don't need to remove the green ABS warning light relay to see the codes. However, changing the relay hasn't made a difference Big Cry 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #712231 13th Jun 2018 6:31pm
L110CDL
I thought i may of been able to help with another ECU, but the RRC i know of is well before 1990 Sad
Could you not call a vehicle electrician in, a mate of mine had a problem like yours and he fixed it Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #712263 13th Jun 2018 9:43pm
grafty99
Thanks for the offer Clayton. I'm fairly certain it isn't an electrical fault - more of a component fault (relay or ECU fault.)
Going to try bridging relays tomorrow to make sure there are no feed backs to the ECU through the relays. I don't think the ECU is exiting diagnostic mode Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #712279 13th Jun 2018 11:14pm
grafty99
MOT booked Mr. Green
Found the problem with the ABS system. As I suspected it wasn't exiting diagnostic mode. All 4 wheel sensors had moved away from the exciter rings.
As non of the sensors were triggering then there was no fault code - even if one sensor had been close enough then I would have seen fault codes for air gap for the other three.
Anyway, all 4 sensors lightly tapped home with a small hammer and drift and the light went off as soon as I reached 4mph. RESULT Thumbs Up Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #712480 15th Jun 2018 5:50pm
grafty99
Perhaps I would have mentioned that until the ABS ECU received a signal from all 4 sensors it remains in diagnostic mode. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #712481 15th Jun 2018 5:51pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Great news George Thumbs Up
Post #712483 15th Jun 2018 5:58pm
mk1collector
Excellent Thumbs Up Ray
My build thread
Post #712484 15th Jun 2018 6:04pm
grafty99
Couple of celebratory pictures Whistle
1990 Vogue SE
Post #712489 15th Jun 2018 6:39pm
Procta
What did procta say Whistle great news mind! Plus it was an easy fix too! I knew it would have been something daft, if you have tested the system with another ECU Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #712496 15th Jun 2018 7:04pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Nice one Grafty,
That looks cracking Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #712511 15th Jun 2018 7:24pm
grafty99
Bow down Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #712518 15th Jun 2018 7:45pm
ian series 1
So what’s the plan with it?
Is it a keeper, or use it for a while sell it and find another project? 80" 80" 86" 88" 90"
Post #712519 15th Jun 2018 8:01pm
grafty99
Definitely a keeper. Lots of family memories in it. Mum and Dad have said I can have it as they don't use it but don't want to see it go!
I was 6 or so when mum and dad bought it and probably about 16 when they stopped using it so most of our family caravanning holiday memories involve the RR in some way or another.
I have permission to do some light modifications such as exhaust etc. But it will be staying relatively standard for the time being Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #712558 15th Jun 2018 11:30pm
