Home > Puma (Tdci) > delay wipers |
DOUG MALGARIN Member Since: 27 Jun 2017 Location: WEYMOUTH Posts: 12 |
My delay wipers has stopped working . Is their a fuse .
6th Jun 2018 7:21pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Is it only the delay that is not working? it's a Landrover thing...
my renovation thread: http://www.defender2.net/forum/topic40792.html |
7th Jun 2018 4:58pm |
Its one fuse for the front wipers
7th Jun 2018 5:34pm |
Click image to enlarge |
7th Jun 2018 5:42pm |
YES got a order a new relay.
7th Jun 2018 9:00pm |
Relay was what I was thinking. Not sure if the Puma has adjustable delay intervals, or if it's like every other Defender and has only 1 delay speed that never seems to be the right one. If that's so, you could get a VW type 99 relay, which would allow you to set your own relay interval time.
https://www.ebay.co.uk/p/VW-Genuine-OE-357955531/652222743 Plug and play! it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
7th Jun 2018 9:08pm |
Puma Defenders are like every other Defender with only a single speed intermittent setting. However, the VW '99' variable speed relay is indeed a plug and play upgrade:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 8th Jun 2018 7:57am. Edited 1 time in total |
7th Jun 2018 9:26pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
^^^as said above best cheap modification you can do
7th Jun 2018 10:19pm |
Its working .New programmable delay relay . Thank for help.
8th Jun 2018 6:42pm |
Ponclair Member Since: 12 Dec 2015 Location: Surrey Posts: 22 |
I also bought one of these from the same ebay seller. Have sent back for refund. Bought one of these instead: https://www.ebay.co.uk/itm/AUDI-VW-SEAT-SK...:rk:1:pf:0
Took about a week to arrive but works as expected. |
1st Dec 2018 11:31am |
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 103 |
How do you adjust delay if you fit VW relay
1st Dec 2018 11:36am |
Switch on delay wipe and switch off again. Wait the desired delay you want then switch on again. Voila!
1st Dec 2018 11:49am |
Flick on 'intermittent' and then off again before it completes it's sweep.
Wait until the screen reaches your 'wet' threshold and then turn on 'intermittent' again. The relay will remember the time between the two operations and repeat until stopped or changed. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Going to have to give this a go
3rd Dec 2018 4:51pm |
