Home > In Car Electronics > Stranded, immobiliser problem? |
Crossfit_Pete Member Since: 07 Feb 2018 Location: N.Essex Posts: 168 |
Driven from Essex to Gretna , stopped for fuel and now won’t start!
Thinking it’s an immobiliser fault? Anyone know a Land Rover friendly garage who might be able to take a look or any other ideas? Cheers |
3rd May 2018 6:39pm |
Cheers, I’ve tried that, no luck but thank you.
Infuriating that they’re supposed to be so easy to steal but you can’t get the immobiliser off when you want to! |
3rd May 2018 7:02pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1805 |
Had something similar on the puma which turned out to be a broken cable in the rear passenger door for the central locking. Would fire but wouldn't run.
Hope you get it sorted swiftly enough 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
3rd May 2018 8:24pm |
StevePotts Member Since: 27 Mar 2018 Location: Staffs Posts: 7 |
I had a similar problem twice. Once it was the battery in the keyfob. The other was oil in the ECU.
6th May 2018 5:27pm |
Not checked oil in the ECU, cheers Steve.
8th May 2018 11:21am |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 678 |
It could be electromagnetic interference. Since our Defenders are aluminum, they make nice, giant antennas that compound the issue.
Try pushing the truck a few meters away from the spot and try to start him up again. Should work when you are out of range of the interference. Such instances are very inconvenient and kind of justify disabling the immobilizer especially on long trips in remote areas. Hopefully, someone can make a solution to fix this concern. Otherwise, a method to turn the immobilizer on and off as required will be a good alternative as well. |
15th May 2018 4:41am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Any news on the problem crossfit_pete ? 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
15th May 2018 9:23pm |
Still can't get it started, trying to arrange for it to be transported to a local specialist (RST).
23rd May 2018 6:26pm |
thanks for the update, hope you get it sorted 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
24th May 2018 10:16pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
I had this once when driving home from work-stopped to go into village shop - came out and it wouldnt turn over.Recovery guy arrived and pulled pwer wire off starter and replaced it. Started straight away. Supposably dirt on the connection etc.
25th May 2018 8:05am |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 755 |
Did you get to the bottom of the problem Pete?
Chris |
25th May 2018 8:23am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
I had a not-starting fault a while ago after I'd been adjusting the bonnet hinges, turned out that I'd tripped the inertia switch on the bulkhead, simple fix. Just a thought
25th May 2018 12:45pm |
