Home > My Defender > here she is |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
Speedo drive and hand brake sorted , exhaust n chassis welding next
21st May 2018 7:32pm |
More patches cut out n replaced with a fresh patch and pure red lead
22nd May 2018 8:55pm |
Lots of enamel paint applied . My series windscreen n glass is finally here , looking forward to that bit
23rd May 2018 7:55pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10364 |
Good for you Razz, seems like all this hard work is going to pay off if you are already excited
24th May 2018 10:43pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
Great work you are doing and your're getting through the jobs now and it will be a well earned play for you 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
24th May 2018 10:44pm |
thank you , i`ve finished the welding tonight , and my new brake pipe is in . the new prop is here , so that can go on next , the new exhaust is next week now as i was too late ordering . bleed the brakes , then fill the transfer box , drive and check , then head to the mud
25th May 2018 6:57pm |
Good job I hardly use it between MOT’s , give me time to fix it , Found another hole or two , so made a start , will finish off another day as to not annoy the neighbours , all the radius arm bushes are shot too , it will never end
27th May 2018 3:43pm |
Finished for now , just gotta clean up the welds n get painting , will poly bush both front radious arms on rebuild
28th May 2018 11:45am |
stanstorey Member Since: 06 Mar 2012 Location: East Devon Posts: 118 |
Looks good - I feel your patching/welding pain
28th May 2018 12:17pm |
Cheers Stan , this area is now red leaded and red enamelled , next up , poly bushes when they arrive , exhaust , and then it must be ready for a pit run , if I find any else on my way , unless bad , will have to wait
28th May 2018 6:10pm |
Looking good there razz, getting it done, but as you said, it will never end time soon to hit the mud 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
30th May 2018 10:46pm |
Thanks fella , i’ve Spun her round n now working on the passenger side , the bushes are shot but the chassis is loads better this side , will bleed the front brake , then it’s at last , exhaust time
31st May 2018 1:17pm |
Drum roll please .......... it’s done ..... till after the mud
Next up , get me muds back on the steels and PLAY TIME Will have a whizz round over the weekend to make sure I got it correct first though Click image to enlarge |
1st Jun 2018 7:39pm |
