Home > My Defender > hanks Double Cab |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Great photos James
22nd Aug 2017 11:47am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
^^^^ 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
23rd Aug 2017 9:08pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 861 |
Looks awesome
How was the job taking the axle off and re installing? Fox dampers are looking good too! How's the ride with them? |
10th May 2018 1:39pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2231 |
Dropping the axle is simple. I hadn't done it before and had the axle off within two hours.
Rather than disconnect the brake lines and having to bleed the calipers on refitting I leave the caliper connected and unbolt/tie up in the wheel arch, Then it's just a case of going round disconnecting things... - Radius arms - Panhard rod - Shock absorbers - Propshaft - Steering box drop link I disconnect the radius arms at the chassis end so that I can lower the axle down on a jack pivoting about their radius which seems more controlled to me |
10th May 2018 2:09pm |
Loving the pics, especially the one with the caddy.............but I may be biased Ray
10th May 2018 2:45pm |
Looking good Hank
I thought you would like the caddy Ray i like where the exhaust is 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
14th May 2018 9:20pm |
This evening's mod... Had one in the house so why not
15th May 2018 8:13pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2072 |
Thats awesome!!
What size strut? Where did you mount it. I must do this! |
15th May 2018 8:22pm |
Basically a Range Rover now
Any feedback on those fox shocks? |
15th May 2018 8:24pm |
Sorry, completely missed your question on the Fox dampers! I can't comment on longevity yet but the build quality is second to none. They seem good, ride quality is greatly improved but that's more than likely due to original's being shot. Expecting the ride to improve again when I swap rear springs for a lower spring rate than the HD ones currently fitted.
Gas strut I had left over from another project but is identical to this https://www.ebay.co.uk/itm/191184708440 |
15th May 2018 8:34pm |
Fitted a new steering drop arm ball joint today. Frustratingly it’s a job I had previously done but when I replaced the steering box recently the nice new ball joint was lost.
So new genuine JLR ball joint kit fitted plus a slight tweak of steering box play adjuster and the steering is now absolutely bang on. No play whatsoever - it has really tansformed the drive! No more constant steering input along straight roads! |
20th May 2018 6:54pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1168 |
Just ordered one of those gas struts
Couldn’t help myself My confidence has been writing cheques that my abilities can't cash for years. |
20th May 2018 10:57pm |
Same here just looks so cool
21st May 2018 6:36am |
Hank , I’m hoping to find time to tackle mine today Any chance you could give an idea of measurements for the pivot mounts positions please Cheers G My confidence has been writing cheques that my abilities can't cash for years. |
3rd Jun 2018 12:54am |
