Home > Td5 > Rocker cover oil leak ! |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Got the dreaded oil leak from the rear of the rocker cover gasket.
Is it best to fit genuine or after market, not B******t ? Mine is a 15P engine so the part number is LVP000020 and does not have the blobs of sealer at the rear. As it was replaced a few years ago I am suspicious the spaces ERR7266 may be shot so will replace those as well. Not sure if I will replace the harness as I have no oil in the red ecu plug but I may just change it as I have it apart. Injector seals sure good so not touching them. Anything else I should do whilst I have access ? Cheers Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
11th May 2018 6:33pm |
Thanks Joris, added to the job sheet !
11th May 2018 8:33pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1571 |
Tend to find that damage when they’ve been drinking diesel.
15th May 2018 11:12pm |
