Home > Maintenance & Modifications > Front dampers - which way up? |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 909 |
Sadly AFAIK both go body up. maybe buy so tubular or D44 turrets to see them. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
1st May 2018 9:11pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 810 |
Here's mine
Click image to enlarge |
1st May 2018 9:17pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7725 |
Body up. My puma has them that way up to. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
1st May 2018 9:20pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2238 |
Thanks all. Body up it is... Gwyn Lewis HD Turrets ordered
#tart |
1st May 2018 9:34pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
How do people find the ride and handling characteristics of the Fox dampers? Also, what can you compare them with? I.e. what else have you tried?
OP- as others have said; body up to help the seals live longer 🤓 2014 Keswick Utility 2.2 |
1st May 2018 9:49pm |
I wrote a few lines on mine in the first response to this thread http://www.defender2.net/forum/topic57966.html?highlight=fox
I have nothing to benchmark them against other than knackered OE dampers but I'm very pleased with mine |
2nd May 2018 1:54pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2278 |
A monotube damper can be fitted either way. Anyway, it is better to keep the body shock away from stones and debris. Puma 110" SW
3rd May 2018 10:19am |
