Home > Maintenance & Modifications > Fitting door hinges
stephan123
Fitting door hinges
Just took delivey of some Optimill door hinges and now contemplating the best way to fit them. Is it best to remove the door or can it be done while leaving the door in situ? I’m a one man band so the fewer parts I remove the better Smile Any other useful tips or suggestions would be much appreciated! Also concerned about how best to make sure door lines up with the seals Shocked
Post #704557 1st May 2018 3:28pm
hank
Keep door closed, remove/replace one hinge at a time. Nice and easy Thumbs Up
Post #704560 1st May 2018 3:37pm
stephan123
Thanks Hank but I thought you need access to the bolt nuts behind the door car to remove the hinges. Means keeping door shut will prove tricky Shocked
Post #704564 1st May 2018 3:54pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
captive nuts are your friend.
Post #704574 1st May 2018 4:27pm
The door bolts are all loose nuts, the B post (if a 110 or 130) have nut plates, so all but the bulkhead bolts require access to the inside of the vehicle (underneath in the case of the second-row door, lower hinge, B post nuts).
The best method usually is to do one hinge at a time and support the door on a jack of some description (obviously with suitable protection between the jack and the door).
Post #704586 1st May 2018 5:39pm
Litch
Take the door-card off and open the window, that way you can reach inside to fit & hold the nuts while the door is held securely by a single hinge and the catch.
Certainly I never have any problems when fitting door-hinges single handed.
And yes, the Optimill items are very nice, have a full set on my 90. ONE LIFE, GET IT!
Post #704621 1st May 2018 8:31pm
zsd-puma
If you don't have central locking/E windows, then you can just take the door off, once the hinges are undone there is only the check strap holding it.
Even if you have electrics, then for 2nd row doors at least there is a plug in the B pilar just unplug the door and lift it off. I would imagine the fronts are the same, but I've not checked.
Another option is to remove the door cards, this allows you to get at the nuts on the door side from inside the vehicle.
Post #704670 1st May 2018 9:56pm
stephan123
Thanks Litch - good call with putting the window down so no need to open the door while swapping the hinges Thumbs Up
Post #704677 1st May 2018 10:24pm
stephan123
Is it the same process for the rear door hinges? I'm hoping that the nuts for the body bolts are also captive Cool
Post #705293 4th May 2018 8:05pm
