Home > Maintenance & Modifications > Exhaust mot and road legal spec please ? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2082 |
Depends on year. Pre 2000ish nothing just do what you want really. Post 2000ish should have a cat if fitted from factory but many are decatted and passed MOTs fine (my two have no problems). 2007+ needs a DPF (and cat I think)
Side exits are fine too just can't be a sharp edge sticking out. |
24th Apr 2018 8:02pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19637 |
DPF only needed on approx 2012 > 2.2 Defenders as fitted by the factory. CAT should be present on all engines. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
24th Apr 2018 8:10pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
As long as it exits after the DPF and Cat it should be ok. I'm sure there are regulations which limit how far it protrudes from the body. Check with the guy who normally does your MOT Defender 90XS SW
24th Apr 2018 8:33pm |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 843 |
Thanks guys, its a TD5 and pre cat , so looks like the only issue i may have is reducing the noise level,
Ill get thinking and scetching away, Watch this space |
25th Apr 2018 5:57am |
Still ahould be fine, my old 90 mpassed its MOT with zero boxes. I eventually put the rear most box back on as was too loud on the mway
25th Apr 2018 6:25am |
