Home > In Car Electronics > 1 or 2 DRL controller's |
Wheel Member Since: 29 May 2014 Location: Essex Posts: 232 |
Gent's.
I'm hoping someone can help regarding wiring up my DRL's. I have 2 pairs of DRL's fitted (2 lights either side), each pair has a controller and I wondered if I need to use both or if I can get away using just one. I was going to wire the outer's on one controller and the inners on the other so I at least have a pair should there be an issue and then got to wonder if I need both. Has anyone any experience of this or similar please ?? Thanks, Mark |
20th Apr 2018 10:20am |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
No reason that they can't run on one BUT you need to check the output current for the controller you use is up to the job of providing power for 4 sets of lights rather than two.
Figure out what power/current each DRL draws then check the specs on the controller. http://www.yorkshireoffroadclub.net/ |
20th Apr 2018 11:33am |
I might be wrong but I thought you were only legally allowed to have one set of drl's on. Ray
20th Apr 2018 11:46am |
Thanks Dave + Ray,
I'm going to go with my original idea to run two controllers, one on the inner and one on the outer set. I like the look of the Urban twin set up which is where I got them + was basically copying that, as for the legalities I honestly don't know but there are plenty around with 4 and I haven't read anything on here regarding them so i'll give them a go and see Mark |
20th Apr 2018 12:48pm |
Not seen that mentioned in any of the legislation, as long as they don't dazzle other drivers there doesn't seem to be a limit on the number of DRLs, would be difficult to implement anyway as many DRL units often consist of multiple lights themselves. They have to have a control unit that either switches them off or dims them for use as side markers so perhaps if you dim them, rather than turn them off with the lights, they need to comply with sidelight positioning regulations too though ? http://www.yorkshireoffroadclub.net/ |
20th Apr 2018 1:01pm |
I thought I saw it in one of Brendan's posts but wasn't certain Ray My build thread http://www.defender2.net/forum/topic17615.html |
20th Apr 2018 6:22pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
I thought I'd seen that you weren't allowed 4. However the new Renault Alpine has 4 definitely separate DRLs 2002 90 Td5 Station Wagon
20th Apr 2018 9:37pm |
Brendan usually puts up links to the legislation so I guess it must have changed if new cars are coming out with more than two. Ray
20th Apr 2018 10:17pm |
Yeah must have, I would say 4 separate lights on this?
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th Apr 2018 10:37pm |
Looks like it to me. Ray
20th Apr 2018 10:38pm |
