Home > Puma (Tdci) > Spigot bearing help
jack1234
Spigot bearing help
Hi all.
As the title suggests. I'm losing the will to live with the spigot bearing. I can not budge it.
Any suggestions on how one might move it.
Cheers Jack
Post #700626 13th Apr 2018 7:50pm
zsd-puma
'Warm' the end of the crank with a blow torch, I say warm because you don't want the thing glowing red hot.
I assume you have a blind bearing puller?
Some good tips here;
http://fordtransit.org/forum/viewtopic.php?f=5&t=156612
Post #700638 13th Apr 2018 8:21pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Drill a hole in it, there is a void between it and the crankshaft,
Either use a slide hammer to pull it out,
Or you can drill a hole to accept a grease nipple and force it out with grease.
I did one a while ago, and did post my findings, they are an absolute Censored to remove!
http://www.defender2.net/forum/topic51595....ng+removal
Good luck Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #700646 13th Apr 2018 8:29pm
NickMc
There’s a special tool for removing them around £60. You have to shatter the center and then insert the puller.
Post #701565 17th Apr 2018 8:18pm
