Home > Technical > Intermittent wiper going to normal speed |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
I would change the relay if i was you. I have a working spare if you want it?
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
11th Apr 2018 1:14pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Thanks Steve, that's a very kind offer, PM to follow. Cheers.
11th Apr 2018 1:42pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Mine does the same thing, tried a new relay to no avail.
12th Apr 2018 8:47pm |
^^^^ have you replaced the switch on yours?
12th Apr 2018 10:16pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Park switch?
My wipers never do intermittent, and I know my park switch is dead (as they don't park, they just stop) |
12th Apr 2018 10:41pm |
My park switch is working, I have not yet replaced the column switch as I was hoping to someone else would say they tried that first.
Mine would sometimes go on intermittent for a while then would just go normal speed, up until a few months ago. Now it is normal speed all the time. I suspect the issue could be corroded wires somewhere behind the dash, possibly the earthing on the relay, or the relay being bypassed altogether. |
13th Apr 2018 8:42am |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
I’d get the switch out and put a multimeter on it - see if something’s shorting or not switching properly first.
Hopefully it’s your relay, then you can use it as an excuse to put a programmable variable intermittent one in. Best of luck! |
13th Apr 2018 9:25am |
