Home > Puma (Tdci) > DCPU Owners, am I high?
Page 1 of 3 123>
Grenadier
Just a quick one for DC owners, or indeed other incredibly knowledgeable sorts, but is my gap between wheel and arch higher than normal? Looks high to me. No 110 DCPUs to compare against, mostly SWs which obviously have more weight in the back.
Photo below, remembering that I have 18" Bowlers shod with BFG ATs 256/75. Just curious, as I will eventually get the Alive Eibach springs which will lower it and wonder by how much. Thumbs Up
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #699870 10th Apr 2018 3:51pm
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
does look a little high. I used to have a 110 csw that used to sit the same as yours. I was convinved that it was down to the bodge self leveller not working. it turned out that someone had put HD springs on the rear for towing
Post #699872 10th Apr 2018 4:08pm
Grenadier
Given the size of my wheels it has always looked high to me. Wonder how I know if they're HD springs? Not that it matters as I'll be replacing them. Tell you what though, handles like an absolute dream. Best 110 I have ever driven. Thumbs Up Monsieur Le Grenadier
Post #699883 10th Apr 2018 4:45pm
AFAIK DCPUs have HD springs as standard to allow a 1-tonne payload, that being said yours does look a little high.
Mine is more or less level, but has done 220k+ miles with at least .5t in the back, but I think when I bought it (and possibly even now if I empty it) the floor of the tub is roughly level with the top of a 255/85x16 KM2, so perhaps not too different to yours.
That's a rusty old drive flange in the middle of that posh wheel!
Post #699905 10th Apr 2018 5:40pm
Grenadier
What's an AFAIK DCPU?
"That's a rusty old drive flange in the middle of that posh wheel!" Embarassed
Yup. Will be tackled with some POR15 (as recommended here) when the snow/rain has definitely stopped. Black bolts as well. Thumbs Up Monsieur Le Grenadier
Post #699906 10th Apr 2018 5:46pm
mk1collector
Thought it looked high but looking at this pic of the mrs dc it's not far off.
Only 16" wheels on hers though. Ray
My build thread
Post #699923 10th Apr 2018 6:20pm
mick
Mines loaded up
Post #699927 10th Apr 2018 6:27pm
CarMan
I believe this will explain the rates, as marked on the springs:
 Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top
Post #699928 10th Apr 2018 6:29pm
zsd-puma
AFAIK = As Far As I Know.
If you go onto topix and look up your build sheet from the VIN, it should state whether HD springs were fitted.
Failing that you'll have to get under there with a torch and try to find the colour codings.
Post #699939 10th Apr 2018 6:51pm
zsd-puma
Why do LHD 110's have different springs to RHD ones? Question Confused
Post #699941 10th Apr 2018 6:53pm
mick
Weight dependant because there’s always a driver but not always a passenger
Post #699946 10th Apr 2018 7:00pm
Sorry, as ZSD has correctly explained, that was me being too idle to type "As far as I know" on a proxy 'phone "keypad".
Post #699948 10th Apr 2018 7:02pm
zsd-puma
That would make sense, except the same applies to RHD vehicles, but they use the same front spring on both sides. Whereas the LHD ones are handed.
Post #699962 10th Apr 2018 7:21pm
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
Maybe also to do with engine position / off centre parts, battery ya de ya such that sitting flat with 2 LDH springs it would be off centre, so this levels it out. TY&GN
10 years in a WOLF, WIMIK and Snatch and this is all I have to show!
Post #699965 10th Apr 2018 7:30pm
zsd-puma
That's true, I suppose the battery for example ends up under the drivers seat rather than being swapped to the passenger side on LHD vehicles.
Post #699968 10th Apr 2018 7:39pm
Page 1 of 3 123>
