Home > Puma (Tdci) > It finally happened....
Likeomg
well she's now 8 so the inevitable first breakdown was long overdue..
overtaking a truck on the m6 out of carlisle towards the lakes, into limp mode, temp gauge up and lots of steam pulled over immediately...
pulled over, refiled the coolant system pretty much lost 2+ litres... got about another mile (just to try and get somewhere safer) gauge went up again so left it, called the AA..
all guesses leading to the head gasket i suppose. Sad
cant see any leaks on any pipes.
Post #699671 9th Apr 2018 8:24pm
JOW240725
Could be leak in pipe or radiator? Not always was to see.
Hope it gets fixed soon!
Should have gone LS3 Whistle James
Instagram @suffolk_rovers
Post #699674 9th Apr 2018 8:31pm
Likeomg
Big Cry
Edit:
James, a LS3 would of been fun... but i have this for when i need my fix of power.
and i dont mean the 109 with a 200TDI Laughing
Post #699675 9th Apr 2018 8:33pm
JOW240725
Thumbs Up Probably handles a little better too!! And I don't mean the 109 Rolling with laughter Rolling with laughter
Part of me always thinks V8 are better in sports cars but then I kick myself that Defenders are not rational things and I'd love V8 Defender! James
Post #699681 9th Apr 2018 8:51pm
Bogus.
Post #699684 9th Apr 2018 8:59pm
Coolant leaks are not always easy to find, I had one on the Waterpump it's self.
Sounds to me like a big leak somewhere but hope it's sorted soon . Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #699697 9th Apr 2018 9:14pm
Likeomg
yeah i just dumped it back at home,
Went over the lakes in the Audi and will be back tomorrow night to start the investigation...
When it cooled down and the AA man put his pressure tester thing on the coolant tank, we didn't have any leaks... seems as it cooled it sealed but this was a quick diagnosis.
Post #699698 9th Apr 2018 9:15pm
Maris Widgeon
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Great taste in vehicles Bow down
Post #699702 9th Apr 2018 9:18pm
MartinK
Good luck with the fix., Likeomg - that does look like the M6 this eve... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #699718 9th Apr 2018 10:00pm
zsd-puma
transits used to have a habit of wearing through coolant hoses. They'd go pop and dump the coolant mist all over the underside.
Post #699754 10th Apr 2018 12:06am
hornet
Re: It finally happened....
Got similar problem. Fixed leakages, changed thermostat. Still limp-mode when pulling hard. They currently dissamble head for gasket inspection/change. Hope there will be a finding at the gasket, otherwise new head needed.
Post #699806 10th Apr 2018 11:04am
I could be barking up the wrong tree, and as suggested could be the head but I had the same symptoms with the Waterpump too.
When hot it would expand and leak from the gasket between the two castings bolted together.
When cold it would pretty much stop, but would always start when hot.
On visual inspection no real leak trace visible, barely tightened it and holed that would sort it and it done it again.
Another new Waterpump and problem solved.
Pressure test wasn't conclusive due to the cold / hot issue.
But you are probably right it may well be the head. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #699828 10th Apr 2018 12:44pm
captain slow
United Kingdom 2014 Defender 110 Puma 2.2 CSW Corris Grey
could it be EGR valves? 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten)
300 Tdi 110 CSW (gone but not forgotten)
Post #699949 10th Apr 2018 7:05pm
Likeomg
I'll start the process tomorrow afternoon...
it was impossible to tell obviously where the water was going / coming as you can see in the pics... it was a typical cumbrian day, although last two days have been rather nice.
maybe EGR cooler?
i don't know whats really in what location yet... but i think it was coming from around the coolant tank area.
Post #700027 10th Apr 2018 9:12pm
zsd-puma
There are a couple of oil cooler hoses that run over the top of the bell housing along side the EGR cooler.
Post #700033 10th Apr 2018 9:21pm
