Installing a working light
I plan on installing a Wipac working light on the rear of my defender. The light has a built in switch so I am going to wire it with a fuse to the purple speaker wire. I am wondering what is the best way to drill the mounting holes so the paint isn't damaged and what are the best sealing options for the mounting and wire holes.
4th Apr 2018 5:57pm
ginjez
Be careful just connecting to a wire in the rear speaker box if the light is halogen bulb. If the bracket is similar to the Lucas oem work light then the bracket is folded in a way to allow the cable to be tucked underneath and concealed under the bracket so as to help prevent water ingress.
4th Apr 2018 6:54pm
LR90XS2011
i did this, little low but no holes in bodywork
Click image to enlargeDEFENDER 90 TDCI XS,
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
