Home > Puma (Tdci) > Engine warning light after clutch change |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
If the engine light has come up there Will be an error code logged. Do you happen to know what is was? a defender from 1984 pretending to be a puma with a touch of Range Rover
4th Apr 2018 6:29am |
phildick Member Since: 29 Jan 2014 Location: Whitley bay Posts: 11 |
They didn't tell me the actual code. They had a diagnostic tool plugged in and said it reported the cat overheating. It is also in and out of limp mode.
4th Apr 2018 8:35am |
Limp mode is a generic outcome of very very many different Problems. I’am failing to see any connection between the clutch and the cat except when removing the clutch they take out the exhaust. Perhaps wiring then? Or temp sensor? Hope that others can be of more help. a defender from 1984 pretending to be a puma with a touch of Range Rover
4th Apr 2018 8:50am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I take it that they checked the EGT sensor wiring,
Sounds to me like wiring or a plug has come adrift around the DPF? Seems a bit odd that your EML wasn’t coming on before the clutch change, Get them to check the wiring again. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
4th Apr 2018 10:13am |
In the end they said it was a sensor had failed. However they replaced a heater element which goes into the DPF I believe.
26th Apr 2018 12:17pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
You have to at least disconnect it to change the clutch so I would be 95% sure they’ve caused the fault.
26th Apr 2018 8:55pm |
In the end they had it in twice, first time for two days second for four days. Charged me only for the new heater element which was 60 odd quid.
26th Apr 2018 10:17pm |
