Home > In Car Electronics > TD5 T/C Off Switch?
bankz5152
TD5 T/C Off Switch?
Looking for a way to build a T/C off switch for my 110 so I can disable it as and when its required. I know Pace4x4 make one but it's not cheap so If I could make my own I would like to!
I am aware turning off the T/C also turns off the ABS.
First idea is a simple one, remove the live off the back of the fuse in dash fuse box and extend it up into a switch, back down and reconnect it. Flicking the switch effectively acts like pulling the fuse.
Now can I do this while the engine is one/driving? Or would that cause issues? Secondly can I turn it back on with the engine running? Or would I have to turn engine off, TC switch on, engine back on.
Any other ideas? I know the Pace 4x4 version uses a relay but not sure what for!
Thanks Smile
Post #696321 26th Mar 2018 8:01pm
bluebottle
In a separate post in the TD5 sub forum, dorsetsmith posted a handy guide to ABS & TC issues, including the info that operating the brake pedal 10 times within 10 seconds with ignition on will disable TC. To re-enable, turn off ignition and then on again apparently.
Post #696369 26th Mar 2018 11:35pm
jst
Correct, as above. Whilst stationary depress brake pedal, coming off completely each time, ten times in ten seconds. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #696379 27th Mar 2018 6:22am
AMBxx
Obvious really Rolling with laughter
Post #696389 27th Mar 2018 7:55am
roel
Yes but I believe it also starts working again if you go above a certain speed.
I cannot check that as I don't have abs on my td5. Roel
2003 90 Td5 (2009-now)
Post #696391 27th Mar 2018 8:17am
bankz5152
Good to know though I would prefer a switch tad easier
Post #696399 27th Mar 2018 8:47am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I just had a look at the Td5 schematics and I see there is a direct connection from the handbrake and low fluid level switches to an input on the ABS module. This leads me to wonder if the ABS is disabled by the operation of the handbrake (and/or low fluid,) it would make sense.
It would be easy enough to check if this is the case by simply pulling the brake lever up one notch, enough to put the warning light on, then drive across a muddy field. If it works you can always add a switch in parallel with the lever switch, this would of course bring the warning light on but that's maybe no bad thing as a reminder.
Post #696445 27th Mar 2018 1:21pm
bankz5152
Interesting that could be perfect!
Post #696455 27th Mar 2018 2:17pm
Boyd
France 2003 Defender 110 Td5 SW Zambezi Silver
Very interested in this as was planning something similar (just off the fuse) that I could use to disable TC and ABS in sand...
If there is any more sensible solution be very interested to hear them Thumbs Up 2003 Zambezi Silver TD5 110 XS SW overland prepped....
2004 Santorini Black TD5 110 XS SW left hooker for sale!
2004 Alpine White TD5 110 left hooker (work in progress)
Post #696457 27th Mar 2018 2:22pm
Clive
Referring to my previous post above, I got the chance to check this out this morning in the snow, driving down the snow-covered steepish hill from my house I dabbed the brakes and the ABS responded immediately, pulled the handbrake lever up one notch, (to put the light on,) and straight away - no ABS action at all, drop the lever down again and the ABS action was restored straight away.
A lot quicker and more positive, (by way of visual indication,) than dabbing the pedal ten times Thumbs Up
Post #697951 2nd Apr 2018 4:00pm
Boyd
Genius! Thumbs Up
I shall be nabbing that.... do we know whether the handbrake switch is a push to make or push to break? But either way I’m sure I could find a local high for the other side of a switch down by the handbrake if needs be. 2003 Zambezi Silver TD5 110 XS SW overland prepped....
Post #697983 2nd Apr 2018 4:53pm
Clive
The HB switch is a simple connection to body earth when the lever is lifted, much like a door pin-switch, tap into the white/yellow wire under the seat box and wire it through a conveniently placed switch to ground and away you go Thumbs Up
Post #698004 2nd Apr 2018 5:42pm
bankz5152
This is good news! I'll have a play the weekend.
Post #698020 2nd Apr 2018 6:08pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Dan at Pace 4x4 does a specific kit to do this 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #698108 2nd Apr 2018 9:14pm
bankz5152
Did you read the OP?
Plus if the handbrake method works then you can turn TC off at any point rather than having the cycle the engine as you do with the Pace kit.
Post #698142 3rd Apr 2018 6:36am
