Home > Td5 > Passenger outside door handle post 2002 |
You need a new door handle and yes, it is straightforward. The door handles are all the same, or at least interchangeable, and are secured to the door from inside with two bolts into brass inserts in the plastic. You'll obviously need to remove the door card and moisture barrier to get at them. The biggest problem is usually that the bolts seize in the brass and pull the insert out of the plastic but as your handle is scrap anyway, it won't matter. Darren
25th Mar 2018 7:46pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I changed to lift up doorhandles. They don't get damaged that easy.
Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
25th Mar 2018 8:35pm |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 148 |
A 2004 from the inside if this is of any help
25th Mar 2018 8:57pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Cheers I've ordered one from eBay for £10 it's not post 2002 but I don't believe there is any difference apart from the locking barrel diameter it takes and my passenger side doesn't have a lock on it.
25th Mar 2018 9:04pm |
Roel, you really need to get some new pictures Darren
25th Mar 2018 9:21pm |
Why? I didn't think I used this one before. Roel
26th Mar 2018 3:37pm |
Do you just pull/knock the right angle pin out or is there an easier way?
24th Apr 2018 9:59am |
You need to prise the little clip off of the shaft with a small screwdriver, or similar. It's fiddly, but easier to put back on again. Darren
24th Apr 2018 10:06am |
Click image to enlarge remove the clip with long noses pliers and remove two screw i.e. the rusty one left hand side in your pic ( red )and the one at broken end of your handle Click image to enlarge one at broken end of your handle on the inside see below Click image to enlarge Last edited by dorsetsmith on 24th Apr 2018 10:53am. Edited 2 times in total |
24th Apr 2018 10:18am |
cheers, yeah that rusty screw's head is like treacle and needs drilling out .. nothing is ever flippin easy on this car ..
24th Apr 2018 10:45am |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 31 |
I ordered a second row door handle as it has no lock barrel, and is considerably cheaper than the correct item. The only thing i had to do was to swap the mechanism over from my own door handle
Click image to enlarge was pointing the wrong way |
24th Apr 2018 11:01am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
Aftermarket handles are junk don’t waste your money the cam on them fouls on the door skin.
24th Apr 2018 11:48pm |
I ordered a second row bearmach handle (no lock) in the end and it fits just fine.
2nd Jun 2018 7:23am |
