Home > Puma (Tdci) > Puma 110 rear sliding windows position.
Bender
Malta 2009 Defender 110 Puma 2.4 USW Bonatti Grey
Hi everybody. Some help please. I own a Defender 2007 utility and am planning to fit TDCI sliding windows to the back. Can anyone give me the exact dimensions where to cut the hole ? (Distance from the top,bottom ,back and front). From photos I'v seen they do not seem to be right in the middle.
Thanks
Post #692662 11th Mar 2018 8:50pm
sewin elwy
Wales 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Right now bender<
Visit the masai site, they have a selection. 2007 windows are different in size to earlier ones although I think they may have been introduced with new radius sizes slightly earlier than 2007. if you want a traditional look make sure you buy the riveted in type with the rubber filler strip. the puma ones are bonded in and you cant service them when the channel/rubbers and felt need replacing they are also a pig to fit with spacer blocks and to remove..... well even worse! or go for the safari panoramic full glass option for ultimate security and water resistance and a cool look. one last option, if its trad you want consider the fixed glass option as no service is required. Ask yourself this..... do you ever open them, not many do!
Post #693283 14th Mar 2018 4:09pm
Bender
Hi thank you for the info. Actually as you said I will go for the TD5 type with the different radius but still have the rivets. I intend to modify them and turn them into gullwings which will enable me to access the fridge from the side. I will take a look at the Masaai Site.
Post #693531 15th Mar 2018 2:52pm
sewin elwy
Hi Bender
HAh Ah! not sure where but I've seen glass trad looking gull wing type opening windows, could well be Masaai!
Post #693535 15th Mar 2018 3:21pm
