Home > Wheels & Tyres > Which tyre for Bowler 16's?
Zed
Thinking of getting some Bowler 16's for the 110 but unsure which tyre to go for.
BFG AT seem the obvious choice but if so what size?
Any suggestions or if you have Bowler's, photos of your setups would be most appreciated.
Post #690771 4th Mar 2018 9:37am
bankz5152
Ive got Cooper ST Maxx 285/75 on mine.
Post #690774 4th Mar 2018 9:44am
Zed
That looks great. Are the extended arches necessary or just for looks?
Post #690778 4th Mar 2018 9:57am
Devon-Rover
Having done a little Rolling Eyes research into my new set of boots recently I would say the Cooper ST maxx has performed brilliantly and do have nice tarmac manners.
Don't get me wrong the BFG at KO2 is a grand tyre and very popular but for me wanting just that bit more ALL in the all terrain and still have good life and road manners than the Cooper ticked a lot of boxes. and for 4 in 235/85 they were ovr £100 cheaper.
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #690789 4th Mar 2018 10:26am
bankz5152
Cheers, they are needed. The tyres are pretty wide as is + 30mm spacers makes for quite a wide track! They sit just inside the arches.
They are great on road, i had STPros before, the difference between the two is like night and day.
Post #690791 4th Mar 2018 10:42am
JOW240725
265x75R16 BFG KO2's. Very pleased with them in all conditions so far, very reassuring. Boringly good in snow Shocked
Just a small collection, if you want more I have a few... hundred Very Happy James
Instagram @suffolk_rovers
Post #690799 4th Mar 2018 11:08am
CarMan
Lovely JOW - I'd like a set and see those wheels quoted as being 7.5" wide on several sites, but Bowler say they are 8" and would hope that they know best, so I'm guessing 265's would be the preferred option as it feels to me that 235's would be a bit small on a rim that width? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top
Post #690820 4th Mar 2018 12:28pm
Zed
Cheers JOW. Looking good and nice to know they handle snow.
Post #690852 4th Mar 2018 3:32pm
UtilityTruck
Assuming you want to keep the suspension and bodywork standard you have about 3 options on an 8” rim
255/85R16 - taller and a little wider than standard. Improves ground clearance, little more tyre of the ground. Really only 2 options for tyre in this size. BFG MT or Toyo open country mt
265/75R16 - Same diameter as the standard size, so same ground clearance. Wider than standard so more tyre on the ground for improved looks and potentially better grip. Many tyre options.
285/75R16 - wider and taller (about the same height as 255/85) But could give problems with the body work at big articulation. Likely to be the heaviest tyre of the 3 options so the suspension will be working harder. Quite a few options on this size.
Bowler typically fit 265/75 in an AT pattern - this was also a size fitted from the factory at some point I believe. 2014 Keswick Utility 2.2
Post #690860 4th Mar 2018 4:25pm
Zed
Thanks for the comprehensive answer. I'm leaning towards 265/75 based on your info and JOW's photos.
Post #690879 4th Mar 2018 5:28pm
CarMan
That's way I'd go Thumbs Up Rob
Post #690883 4th Mar 2018 5:52pm
Sulisuli
Very comprehensive and informative reply “ Utility Truck “ Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #690885 4th Mar 2018 5:56pm
