Home > My Defender > I've been Tangoed!
Page 3 of 4 <1234>
Crossfit_Pete
United Kingdom 2007 Defender 90 Puma 2.4 CSW Firenze Red
Any idea what this is?
Might have to re-think the jack mounting,
Has a split charge system, need to figure out exactly what does what,
Post #686058 12th Feb 2018 3:01pm
AndrewS
Jack stand/base
 130's have feeling's as well you know Smile
Post #686060 12th Feb 2018 3:03pm
Crossfit_Pete
Ah! Thank you Thumbs Up
Post #686062 12th Feb 2018 3:05pm
Crossfit_Pete
Parts arrived for the dreaded starter motor rebuild Crying or Very sad
Post #686398 13th Feb 2018 8:06pm
L110CDL
Nice lot of extra stuff you got with the landy Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #686435 13th Feb 2018 9:48pm
JWL
Don't worry about it Crossfit_Pete, 13mm socket for the two bolts you can see and a 15mm socket with plenty of extensions for the one nut you can't.
I generally get underneath and disconnect the main power lead and tape it up to prevent any arcing as opposed to lifting the seat and disconnecting the battery.
As soon as it's off it is onle a 10 minute job to change the solonoid and contacts Wink
Post #686465 13th Feb 2018 10:49pm
Crossfit_Pete
Cheers, this is quite far out of my comfort zone but I'm taking on advice that I really should get to know the vehicle a bit more if I'm going traveling in it!
Will report back tomorrow, providing it doesn't rain all day!
Post #686468 13th Feb 2018 10:54pm
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Re: I've been Tangoed!
Crossfit_Pete wrote:
Just returned from a very tiring trip to Hereford to collect this,
Six hour train journey yesterday, restless night in a Travelodge and a 4 1/2 hour drive home this morning.
It's a G4 lookalike, Td5 with a few mods, actually goes really well! 70mph in a Land Rover is a totally new experience to me!
Overall I'm really happy with it but the starter appears to be on the way out so I'm going to have a go at re-building it next week.
Watch this space!
She's a Hampshire Girl Thumbs Up 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #686508 14th Feb 2018 9:07am
Crossfit_Pete
Yes, there are receipts from Harwoods Land Rover Thumbs Up
Post #686519 14th Feb 2018 10:02am
Crossfit_Pete
Attempted the Starter today!
Removed engine cover and spent about 10mins trying to see where the nut of doom actually lived. Combination of my bad eyesight and poor light.
It's down there somewhere,
Got a torch and yes, bare threads! There was no nut Rolling with laughter
So, disconnect the battery,
Confusion Confused , luckily the PO had shown me the battery cut out!
10 mins later, which included taping up the ends of the cables 'just in case' and having to get the jack handle to use as a mini breaker bar and, het presto.
Genuine Land Rover starter,
Seen better days though.
Followed the X8R video on YouTube for the re-build, also bought their kit on the basis that if they can be bothered to put a video up I don't mind supporting them.
Very straight forward,
Took about 30mins, taking it very slowly and drinking coffee etc.
Another 5 mins to bolt it back up and it fired up first time.
The starter was intermittant before so not 100% sure it's cured but fingers crossed!
Post #686580 14th Feb 2018 3:06pm
Crossfit_Pete
Another little job was to fit a cheapo 'snow cowl', just because I like the look Cool
Took the old vent off and there was a massive amount of mud/sand in there,
Scooped it out and ran some water through, there's actually a drain hole Shocked
Fitted the cowl,
Thumbs Up
Post #686584 14th Feb 2018 3:12pm
L110CDL
Great you got it sorted out and fingers crossed it will keep on going like it should do Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #686847 15th Feb 2018 9:13pm
xcentric
looks like you've done your first repair all successfully. Mine was the same - get used to the vehicle by working on it. Again, like you, it didn't take too long- though I spent a fruitless half hour in nearly removing the alternator before I twigged..... Embarassed
Post #686860 15th Feb 2018 9:49pm
Crossfit_Pete
We've had a fair bit of rain this week and I've noticed a few leaks!
I suspect the safari windows for this,
The front windscreen looks like it's also leaking, need to get this sorted.
When I bought it the seller mentioned an access panel for the fuel pump, thought I'd better investigate. Not bad to get to but had to remove the draw, which was a bit fiddly.
Post #687085 16th Feb 2018 11:09pm
Crossfit_Pete
Did a couple of bits today,
Fitted the Mantec Tufflift, I always wanted to try one since I saw tem fitted to the Wolf. Pretty easy to fit, just two nuts to the carrier and adjust the straps (which was a bit of a faff)
Overall impression, not sure it was worth the effort but does make lifting the spare easier.
Had a KBX Grille and light surrounds that I took off an old ex-Military 90 I had so I thought I'd see what it looks like. Not sure to be honest, will see what it looks like wit the surrounds if I change to LED lights. It might offer a bit more protection to the intercooler?
Also bought these in preparation for the oil change,
Post #688295 22nd Feb 2018 9:11pm
Page 3 of 4 <1234>
