Home > Td5 > Hazard and indicator issues |
Evening Pardeep. According to the wiring diagram there is a satellite fuse (F31) for the hazard switch (15A) attached to a purple/brown wire. If this blows then when the hazard switch is pressed no power gets to the switch or the indicators. However when the ignition is on power will get to the indicators via fuse F21 (10A).
Click image to enlarge |
11th Jan 2018 10:20pm |
Pardeep Member Since: 12 Jan 2016 Location: Birmingham Posts: 70 |
Evening geobloke,
That’s great. I’ll take a look tomorrow and hopefully have it sorted, I suspect it’s going to require getting the modified dash out but I’ll check under the seat first as that’s where the wire seems to be going. |
11th Jan 2018 10:47pm |
Does anyone know where this inline fuse is? I've had a look behind the instrument cluster, dash, fuse box and under seat fuse box but can't seem to see it anywhere.
31st Jan 2018 4:24pm |
is your TD5 pre 2001 or post
31st Jan 2018 4:50pm |
It’s a 2004 car.
31st Jan 2018 4:53pm |
It’s a 2004 car.
have look below fuse 31 15amp
31st Jan 2018 5:02pm |
Ok so I believe it’s Fuse 31 which is in the satellite fuse. Is this fuse 31 in the passenger compartment as that fuse as do all the other fuses seem fine.
31st Jan 2018 5:10pm |
That`s right shown as satellite fuse. in drawing but in passenger compartment fuse box
31st Jan 2018 5:17pm |
