Home > Maintenance & Modifications > Britpart Cubby Box Install
hinsonberger
New Zealand 2003 Defender 110 Td5 XS CSW Zambezi Silver
Hi all.
Quick question about the basic Britpart cubby box DA2035. Does the cup holder at the front come out?
I'm trying to install the box, & presumed the cup holder pulls out so you can drill through the base beneath it. If it does come out, it is stuck in unbelievably well!! I tried to gently lever it out but don't want to damage the cubby box if it doesn't. It's not the most robust cubby box on the market Laughing
Post #676933 8th Jan 2018 7:17pm
zsd-puma
The genuine ones aren't the most robust either, I expect it's from the same supplier. It should pull out.
Post #677051 8th Jan 2018 11:04pm
rallysteve
It is normally glued down. I had to lever mine out to drill some screw holes beneath it for the mounting screws. You could re-glue if you wanted but i habe left mine loose so i can get to the screws to remove.
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #677057 8th Jan 2018 11:13pm
miker
It's glued down with two big splodges of hot glue. I removed mine to run the wires in for my heated seat switches without too much hassle.
I ended up drilling the removable centre panel and screwing the cubby box down upwards from below
Post #677075 8th Jan 2018 11:36pm
hinsonberger
Thanks guys! I just need to be a bit more brutal by the sounds of it Thumbs Up
I'll give it a go & report back.
Post #677103 9th Jan 2018 3:53am
rustandoil
As said, the cup holder is held in with a couple of blobs of hot glue, I popped mine out with levering with something wide, like a wallpaper scraper to reduce the risk of damage. Thumbs Up
Post #677113 9th Jan 2018 7:49am
hinsonberger
Success!!
As suggested, with the use of a wide scraper, some constant pressure & some cloth to protect the vinyl; the cup holder came out.
Thanks for the tips.
Post #682829 30th Jan 2018 9:32am
rustandoil
Thumbs Up
Post #682836 30th Jan 2018 10:17am
