Home > In Car Electronics > Rear Speakers Wiring post 02 TD5 |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Should be there Rear with rear light wiring
Doesn’t always mean it’s in the connector block at the front though Let me know if you need some rear speaker pods I have a pair with uprated speakers for sale 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
2nd Jan 2018 5:04pm |
Click image to enlarge black yellow / black orange LH black green / black blue RH if wiring is in place at the back |
2nd Jan 2018 5:30pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Cheers all, if its there where would i find it?
2nd Jan 2018 6:00pm |
Click image to enlarge and LH D post behind metal work cover both side |
2nd Jan 2018 6:04pm |
cool ill take a look, i assume from that pic that is what the inside of the metal box bit looks like in the rear corners
2nd Jan 2018 6:08pm |
2nd Jan 2018 6:09pm |
yep interested and have sent you a PM |
2nd Jan 2018 6:10pm |
if i buy the rear speaker Pods from the PUMA and rim them to fit my TD5 SW , how do they fix in place ?
4th Jan 2018 1:53pm |
Piggy501 Member Since: 27 Sep 2017 Location: Scotland Posts: 56 |
This is likely a stupid question, but where does the rear wiring harness run? Am I right in thinking it's through the chassis rails? The reason I ask is I'm going to add speakers to an '01 CSW but I can't find any evidence of existing connectors, and I'd like to run the new cable with the existing wiring harness to keep it all together, as long as it isn't too difficult to access and add to.
7th Jan 2018 12:18am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
It would run through the chassis with the rest of the wiring.
Best option to run across back of dash and up side of windscreen, then along internal guttering under headlining. Then down behind trim beside rear door. |
7th Jan 2018 6:25pm |
